You guys are all crazy with these SATA cables, filters, etc!
Edorr you could have got this chassis:
http://www.shop.perfecthometheater....file-HTPC-aluminum-chassis-HTPC-FC10-OD-B.htm. That's the one I'm using
Also I think my AudioPhilleo USB/SPDIF converter sounds better than the Lynx AES16e into my DEQX HDP4.
Nyal, "crazy" is quite an apt description. In my experience, some of these tweaks do absolutely nothing, others do. Unfortunately, only way to find out is ask a few fellow crazies for their opinion, take the leap and hear for yourself.
The FC10 chassis is exactly what I am getting - based on you earlier mentioning it (I also just ordered some drapes from rosebrand - I do listen to you!). However, it is out of stock in the US, so I'm ordering it from the UK. The only fanless alternative that can accomodate 2 cards is a tower, which I don't want.
I will be using the Lynx card stictly for MCH. The Multi-channel AES/EBU outs from the lynx card will initially go into my Trinnov processor. Next, I will install Dirac Live on the server and try to take the Trinnov out of the chain.
For 2 channel I will use the SotM USB card into the USB input on my MSB. USB direct into my DAC sounded better than my offramp 5 converter, so I got all bases covered.
I believe you are doing the same thing (USB for 2 channel, Lynx for MCH), but use the USB from the motherboard instead of the SotM card. I am also getting the battery powersupply.
