ANY speaker out there (other than Horns) that can match $999 Zu Omen Dirty Weekend Dynamics?
caesar
775
1,698
I imagine the $999 Zu model lacks resolution and refinement, but is there anything out there even close, other than the big horns, that match its dynamics, snappiness, and impact?
bonzo75
22,646
13,677
2,710
London
I TOLD you not to read too many of Marc's posts. You begin to feel sleepy.. sleepy... sleepy... And then bang you wake up and you are under his hypnotic spell
Lee
3,249
1,778
1,260
Alpharetta, Georgia
The Alexia 2s do it well.
JackD201
1,429
1,820
Manila, Philippines
The Zus are actually over 2k for the pair. That said, I really admire what Clayton Shaw has been able to do for very little money. I believe he was behind Emerald Physics. Now he has Spatial Audio.
Even the Baby M2 can party hard. In my thinking that snap and impact is most easily achieved with a large, light diaphragm on the woofer like the Zus have. The Spatial Audios have got those too.
....correction on my part. The Dirty Weekends are indeed 999 per pair as opposed to the Omen Mk2 I presume Rated PG weekend :D The M2s also appear to be discontinued. Spec wise the M3 Triodemaster is the most similar but is almost 4x the price.
morricab
9,531
5,068
1,228
Switzerland
You mean for the money or at any price?
For the money, the Decware HDTs give a good account of themselves for $2.5K.
caesar
775
1,698
Hahahaha. I think I'm too much of an audiophile snob to go with Zu in my primary system...
But I haven't heard Marc's system, and I haven't heard the top of the line Zus. From what I understand from Marc, he is completely entranced and emotionally engaged in every listening session - after 20 years of searching for the holy grail. He is completely into the music and not aware of any limitations of the gear. It's what he had always dreamed about. And he's not the only Zu owner to say that. Some guys wait 30-40 years for that experience and stumble upon Zu.
From what I know, Zus are a huge blast rock n roll. Not sure about classical or jazz. I wouldn't mind picking up a pair of dirty weekends fro $999 for the pure fun of the hobby. Guys pay more for a cable or an anti-vibration gooter.
KeithR
5,174
2,863
1,898
Encino, CA
Its a fun loudspeaker - have a friend with a pair of the first edition. They sit a bit low, so you have to play with rake a bit. Classical probably isn't their strength.
caesar
775
1,698
Thanks. I think other than horns, I have not heard anything as dynamic. So I am just plain curious. Zu is always compared to high-efficiency Devore. But I think the Zu is more dynamic than Devore (while the Zu cheaper models are supposedly less refined than the Devores).
caesar
775
1,698
Hi Lee,
That will be an interesting comparo. I would put my money on the Zu over any $50-60K box speaker, dynamics-wise, but I don't know....
If Zu is your cup of tea, I would love to read your thoughts on it. Maybe Zu can get you a pair of their top of the line to review and compare against the Wilsons... If Zu didn't sell direct, the prices would be in the ball park.
DaveC
3,899
2,142
495
Dynamics are a function of mechanical impedance match with the air, so large diaphragm surface area or horns, and motor strength of the driver.
So if you care about dynamics and price maybe Cerwin Vega or some white-van speakers? :p
If price isn't a factor most any speaker with larger woofer surface area and not open baffle, which is inefficient, should beat them.
Lee
3,249
1,778
1,260
Alpharetta, Georgia
I'm a big Zu fan and they have good parties at RMAF every year. I think their top of the line is around $30K a pair and they are superb. But the Alexias are a different level as they should be for twice the money.
Hi Lee,
caesar
775
1,698
Not in the dynamics arena. :)
And I know this is subjective, not in emotional engagement. I take a $4K Zu over any wilson, excepting alexandria, if I am listening to rock n roll. :)
spiritofmusic
14,626
5,435
1,278
E. England
Hey, as WBF's resident Zu booster, do you need my input Caesar LOL?
If only you could hear my Zus, you'd lose your (reasonable) bias that they're only good for rock.
caesar
775
1,698
Hi Spirit,
Yes, I am experientially impoverished in that regard.
Also, since you are so familiar with the brand, do you have any thoughts on the original question? Thanks
caesar
775
1,698
Hi Dave,
I am not sure what they are doing, but it may be more than the size of the driver, which measures 10". They also use some other engineering trickery... here's some marketing language ...
"The center cylinder (phase plug) in a Zu 10” driver
A machined phase plug assembly, which is not in motion, directly connect to the frame/motor assembly, with both visible and hidden features allowing for the following benefits:
Extending high frequency limits of the driver assembly through a combination of whizzer cone and center pole detail profile and acoustic impedance matching.
MLS diffuser function of pole piece profile and rings aids in the widening of the high frequency (polar plot or beam pattern).
Aids in control of dynamic behavior through diamagnetic shunting (shorting) of spurious B fields.
Zu’s implementation of shunting is regulated, providing virtually no dynamic damping at low level play and increasing logarithmically to maximum in high SPL play.
Dramatic improvement in cooling as the assembly is press fit and uses thermally conductive adhesive. (Only significantly in play when you are pushing huge power, but there nonetheless.)"
and...
"Zu-Griewe driver/box/acoustic loading technology, developed by Sean Casey and the late Ron Griewe, allows improved driver-to-room coupling, fidelity, and bandwidth.
Let us introduce you to Zu’s driver/box/acoustic impedance matching technology. Zu has designed a speaker-driver/box/room loading technology that reduces the acoustic impedance ratio of loudspeaker cone to room, thereby increasing efficiency and reducing cone motion. This original technology significantly widens the usable bandwidth and reduces distortion. It does not introduce distortions common to horn-loaded speakers and is operable through several octaves."
Here's some "white paper stuff"/ marketing:
https://www.zuaudio.com/questions-list/2013/8/18/what-is-a-full-range-driver
https://www.zuaudio.com/questions-list/2013/8/18/tell-me-more-about-zus-10-full-range-driver
https://www.zuaudio.com/questions-list/2013/8/18/what-makes-zu-loudspeakers-so-good
spiritofmusic
14,626
5,435
1,278
E. England
Caesar, it's taken me a long time to crack the Zu combination.
And now I reach for my classical Lps first.
I'd seriously audition Zus further before finally choosing to keep them or dismiss them as rock spkrs only.
So yes, they are rock speakers first, but they're serious all rounders as well.
KeithR
5,174
2,863
1,898
Encino, CA
caesar- I own Devore Gibbon Xs, but would pick the Zu Druid VI over Devore's O/96 competitor if SET amps and the like is the goal. The O/96 has really plump bass to me. It might work ok for jazz, but when electronica is put on it watch out!
morricab
9,531
5,068
1,228
Switzerland
Well, I have heard Zu Druids and another model (can't remember anymore the name) and the HDTs are just as dynamic with a modified Foxtex driver (96db) and good bass to about 40 hz. Another non-horn that is probably as, if not more, dynamic than Zu but somewhat expensive is Horning. Used though, there are some good deals to be had on Hornings.
