Okay, a straightforward one ...
As the title says, who has speakers that have disappeared, and why do you think so? If possible, as a special treat for all, tell us where do you think they've gone?
Frank
The door was broken off the hinges so I assume.....
Just kidding. What do you mean by invisible speakers? To get any kind of accurate response, that's going to require some defining. Here's my definition:
When you close your eyes and listen you can't tell where they are....no, that doesn't work. I
know where they are, so there's too much psychology involved.
There are instruments and voices in a field between and maybe even beyond the speakers, they don't seem to coming from the speakers exclusively...probably not good enough, even more psychology involved. OK, this one works because it is so hard to make your brain do it for you --
Play something that is well recorded in mono. close your eyes and hit play, if you're using box speakers (not dipoles or bipoles, they disappear differently) the sound stage should collapse toward the center. Your speakers should
actually disappear, replaced by a single center channel speaker.
And yes, mine do this. Where did they go? They went into good, quiet components. They went into excellent channel separation. They went into excess headroom. They went into superb driver control. They went into careful room placement.
Tim
