Zero Distortion: Oswald Mills - the OMA OMG tour
Folsom
6,030
1,503
550
Eastern WA
Sure, a quarter wavelength gives you an output, but it isnt a true CD. Also I dont think anyone was specifically referncing folded horns. While it had similarities, it really isnt the point. True CD horns can have phase that other speakers cannot.
DaveC
3,899
2,142
495
Imo, directivity < 400 Hz or so is overrated.
awsmone
1,616
514
435
Canberra Australia
Once the wavelength equal size of speaker then it’s P1
Horns of CD design will at low frequencies be dominated by higher modes perceptions, and the issues are clearly audible, as Dave C points out the CD horn advantages dissipate at low frequencies I have often wondered if this is the reason that JBL have never bothered with this in their low frequency transducers ?
morricab
9,531
5,068
1,228
Switzerland
Straight or folded the needed length is the same. If you have room for a 3 meter straight exponential horn or two then you could do that as well.
