69-70 Hz problem: advice requested
ayreman
217
78
158
Ukraine
In my listening room I have a problem with bass at 69-70 Hz: bass is very boomy at this frequency. Is there a way to somehow mitigate this problem without affecting other frequencies which I'm quite happy with? Any advice and/or recommendations are much appreciated.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
the 60-80Hz range is problematic in every room.
Some of the things to help:
Bass traps - never can have too many!
Speaker/Listening positioning.
Subs with DSP - adding more bass seems counter intuitive, but, if you can get an out of phase signal at the problem frequencies, it helps.
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
one thing to try that is cheap and can work is to experiment with speaker and subwoofer height. the floor-bass driver relationship can affect the mid bass quite a bit.
it might not matter, but it might help.
you can get some sort of platform, or longer spikes, or even a few blocks of hardwood. in any case it's small effort to investigate. 2 inches can make a big difference in bass hookup in certain frequencies. the floor has a much larger effect on bass than other surfaces. do experiment with varying heights as small changes in floor-driver distance can make big differences.
in my old room when I had Watt Puppy 5.1's back in 1998 I was able to smooth out my bass in this way. the room was small and I already had tube traps. so my options were limited.
keep in mind raising the main speakers raises your tweeters and mids, so you might need to slant them to keep your listening height the same.
mcduman
126
4
325
nope. used to have the same problem. do not blindly waste your time and energy on accessories before finding out the exact boundary that is interacting with your loudspeakers to create this 70 Hz peak. do the (sub) woofer crawl first by placing one of your speakers in your listening position. play a 70 Hz tone and walk along the perimeter of your room to see the what it is that is resonating. you will realize it is shamefully obvious what the exact problem is.
https://www.youtube.com/watch?v=R4o13mNmlaA
andromedaaudio
8,495
2,841
1,400
Amsterdam holland
First i would look at is the speakercabinet .
Is it a boomy design meaning is the bassdriver setting the whole housing in motion ?:p
Rodney Gold
983
11
18
Cape Town South Africa
You have a PC as a transport.. not using analog sources as per your sig
If your player has a dsp parametric eq section , use it
Programs like J river and roon have them
Program in a dip of -6db , centred around 69hz, vary the Q from 3 to 5 in the parametric eq section
You could also use full time and freq room correction like DIRAC or Acourate and set them only to work below 250hz or so .. so you dont mess with upper freqs and only work in the bass
You should easily tame that beastly bass and more if you want
sbo6
1,678
605
480
Round Rock, TX
Rel Stentors are great subs, I had one not too long ago. With two of them and careful placement (including potentially lifting off the ground) you should be able to "control" that bass node at the listening seat. Also, more bass traps in corners is not always the best approach, many room have "dead' corners relative to the listening spot and adding traps just deadens the life out of the room and does nothing to manage bass. Room EQ Wizard is your friend. Measure and move, measure and move, then do final listening / placement tweaking for the last 2%.
Jim Smith
203
177
948
79
First, IMO - Move the listening seat forward & back a bit and note the differences.
You will find a position where the peak is less problematic, although other peaks or dips are likely to appear.
If you are measuring, be sure to do all measurements at ear height, so that you seeing the room-height interaction as well as possible, otherwise the measurements won't exactly tell you what is happening.
Choose the seating position where the room interacts least in the bass - in other words, where the bass is smoothest.
This is nearly always the most important (not to mention inexpensive) first step - definitely done before moving the speakers to fine tune.
In fact, without first establishing this 'smoothest bass' listening position (which becomes the anchor point), moving the speakers about is much less useful.
ayreman
217
78
158
Ukraine
How nice of you to post here, Jim! You are the very person I need now. I've just sent you an e-mail about my issue and hope to hear back from you.
Loheswaran
437
101
273
Elberoth
2,011
259
1,170
Poland
+1
bonzo75
22,646
13,677
2,710
London
+2
bpape
7
3
3
65
What is the height of the room? If about 2.4m (8') it could easily be a height mode. Try just standing up where you are now without changing anything else and see if the problem is helped.
