What are the best movie scenes to test and show-off sub-woofers?
1. There was a build thread detailing the subwoofer in the video. One way to go if you are building a dedicated room. I cannot remember which forum it was on.
2. I would love to build a dedicated room with Seaton subs to replace my JL Audio F113's.
1. http://www.whatsbestforum.com/showthread.php?2646-Rotary-Woofer-facts&p=35426&viewfull=1#post35426
2. http://www.whatsbestforum.com/showt...bottom-of-it-all&p=38058&viewfull=1#post38058
_______
Another great scene to show off your subs is: The Server Room (Computer Center lab) scene (Part 2) from the movie Pulse (2006).
* Best on Blu-ray (also avail on DVD)...roughly from 1:12:00 to 1:14:00
* Bonus: http://data-bass.ipbhost.com/index.php?/topic/134-the-longest-most-intense-bass-scenes-from-movies/
The TRW-17's specified frequency range is 1 to 30Hz (±4dB) with a maximum acoustic output greater than 115dB SPL from 1 to 20Hz. As a result, a conventional sub is required to fill in from there to the point at which the main speakers take over, which is typically 80Hz or so.
Read more at http://www.soundandvision.com/content/eminent-technology-trw-17-rotary-subwoofer#9Uk5EcQZ2w2REhEZ.99
Requires a room or very large box as an enclosure, and is limited to 115db, 13K dollars. Cool design though.
Nice, but that one in the video was a DIY version based on the same principle.
The info about using a manifold for for damping the sound off the blades and using the room is intriguing though, it's like the extreme end of using open-baffles where the room is put to good use.
