Nagra Introduces Classic DAC at CES 2016
jfrech
2,157
753
1,160
Austin
I'm sure this dac hits a lower price point, fills out their "Classic" range also. I suspect the Classic DAC with the new Classic Integrated amp is a killer combo that would shock folks spending a LOT more.
I'm with you..I'd love a DSD recorder from Nagra...that might get me to start digitizing my vinyl...
Lee
3,249
1,778
1,260
Alpharetta, Georgia
Knowing Andreas is involved I bet this sounds good. I'm also curious about the Chord DAVE.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
These were at the show today:
Alas I have no notes on it which usually means they were not playing any music. I love the industrial design. If i have time I will go there again if there is interest in how they perform.
jfrech
2,157
753
1,160
Austin
I bought the Classic Amp recently. It's a pretty special amp...I bet you'll like the sound of this system...
spiritofmusic
14,626
5,435
1,278
E. England
J, have you moved from yr Ayres? I thought you loved 'em?
jfrech
2,157
753
1,160
Austin
The MX-R's are great amps. Nothing bad to say about them. The Nagra Classic Amp possesses more resolution, better portrayal of space, deeper/tighter extremes...albeit at a lower power output. The MX-R's NEVER ran out of gas...always effortless...The single Nagra I just have to be a little careful-not much however...and I listen to Jazz, acoustic and light classical...mostly...which it's perfect for.
bmichels
109
2
260
Today, with my BHSE tube amp + Stax SR009, I compared quite intensively the dCS Rossini DAC and the NAGRA HD DAC.
The NAGRA HD DAC with my BHSE was by far the most involving and enjoyable ! I Finally got some saoul & spirit into my music :) ! Much more than with TotalDAC, DAVE or Rossini, all 3 being very precise and detailed but... NOT very exciting :-(
Until I heard the HD DAC, I had the feeling that all those high-end DAC sounded almost the same, but with HD DAC there is something more, some emotion I did not get with the other DACs
I wonder if the Classic DAC will bring the same magic or if I really need to get the HD to get this feeling ?
jfrech
2,157
753
1,160
Austin
I'm a HUGE Nagra fan, their gear nearly always punches above it's weight class. Seems like the Classic DAC requires a preamp and drops the tube output stage.
I think this depends on your preamp, if you have a killer preamp, then you maybe happy with the Classic DAC for less $$'s. However, make no mistake, Nagra builds GREAT preamps, and the charm you're hearing maybe partially from the preamp stage in the HD DAC. I have a Nagra MPS power supply on my Nagra Phono stage...it's important to as is the Nagra VFS plates...
I've heard the HD DAC vs the Vivaldi...I know the HD DAC is VERY good...doesn't surprise me on your reaction...I'm still a Vivaldi guy...but that HD DAC could make me waver too at that price point...
4,702
Probably you enjoyed the effect of the tube and transformer coupling of the HD DAC in your system. ;) The Classic DAC has a similar digital and converter section, but no tubes and no special separate analog and digital power supplies, but almost the double of the price.
I have looked at the HD DAC it a few months ago, but unfortunately I really wanted a network input. The internal processing is DSD128 - that is not the highest resolution anymore today, contrary to what is written in their brochure. IMHO you should ask if they are considering upgrading it to DSD256.
DaveC
3,899
2,142
495
I approached the NAGRA rep to use their CDP/DAC at AXPONA 2017 after hearing them at shows. The music just flowed, very enjoyable to listen to, no hardness. Good to see you had a similar impression of their DAC.
