Slightly Warm Speaker cables
nirodha
694
308
1,625
Merrill,
If you make the statement that higher inductance speaker cables sound warm, my assumption is that that specific 'warmth' is due to the fact that the inductance is forming a distributed lowpass filter, nothing more, nothing less. If the 'Newtonian' in me made an incorrect assumption, my apologies....
FWIW,
Paul
I think "warm" as in cables is about as hard to define as "musical". I would also try some cables from a cable "library". Good luck! :)
merrillaudio
Merrill,
FWIW,
Paul
Absolutely no need to, your assumption is correct on low pass, with low being outside the hearing range/measuring range but still affecting the transient response. So you are correct on LP assumptions.
Great plan. Every one (and I am not kidding), loan spare cables to Joe. Best way to try them out, after they have broken in.
racerxnet
86
33
323
I would agree that tuning the sound with cables is a difficult task. Room interaction and treatment if not done already, may go a lot further than 5K on cables. For me, if the sound does not suit my tastes, I sell the speakers and buy another set more suitable. Speakers alone have the biggest impact on sound perception of all components.
MAK
Bodhi
1,051
361
155
MAK
+ 1. My philosophy is build your system around your speakers & keep your system balanced (ie: no weak links).
MrAcoustat
847
7
Quebec Canada
Hi,
Still looking for slightly warm speaker cables for my Gryphon Mephisto Stereo to ProAc Carbon 8.
Like a Cardas Clear but not Cardas - blows up the amp (see other thread)
Budget USD 5K for a 2.5m pair.
Regards,
Joe Ling
Hi Joe i have a buddy a ( wealthy ) buddy he as 38k worth of cables in his system he as tried many many makes - Nirvana - Siltech - Cardas - Stealth - and many more he as chosen ALL ( Purist Audio Design ) top of the line cable and he is FINALY happy here is a few photos of his system.
Système Elrocco 01.jpg Système Elrocco 02.jpg Système Elrocco 03.jpg Système Elrocco 04.jpg Système Elrocco 07.jpg
joeling
177
51
335
Thanks guys for all the valuable information & advice.
MrAcoustat
847
7
Quebec Canada
I agree 100% this is why i have been with Acoustat since 1984, yes i know that the company folded in 1991 ( USA ) for me after that it was NEVER Acoustat, Acoustat Italy - Acoustat China - there was only one real Acoustat company and they where in the USA. you find a speaker that you like and work the system around them and you will be a happy man.
PS: This is what a happy man look's like - - - MrAcoustat & Speaker.JPG
Kryzyz
3
Pasadena CA
Paul, I found your post to be highly informative. I tried the Audioquest biwire configuration on my YG Anat III Signatures and perceived it to be "warmer" and preferable to biwiring as well.
Can you comment on the difference between Jorma Prime and Origo cables both of which are of interest to me?
Occam
[Industry Expert]
Dec 15, 2010
117
1
NYC
Kryyx,
The Primes are 'warmer' than the Origos. But that 'warmth' from the Primes isn't at the expense of an over emphasized mid-range, but rather subjectively, a denser midrange while keeping extension. I've heard them both as ICs, in different systems, sometimes together, and they worked quite well. Using stereotypes, I'd call call the Primes 'tubey' to the Origo's 'solid state' signature, both in a good way. If you're in the States, talk to is Dan Meinwald of Ear-USA. the US distributor for Jorma. At shows, Dan will inevitably have a really excellent sounding room with Marten speakers, EAR electronics, and Jorma cables. FWIW
-Paul
