Footers for heavy speakers
an.vamv
31
20
313
Hello there,
Can someone recommend any footers or spike bases for heavy speakers around 350 kg ? Most products i see in the market seem to have a limitation below 300kg.
Thanks
Reactions: PhP
Finite Element Classic footers.
End of the line product , easy to slide / move the speakers even for a single person
Spikes are horrible for moving / sliding the speakers
Thanks for the suggestion. Can these be screwed directly onto the speakers and if yes with what bolt size?
I have M 8 inserts under the speakers and i screw them drectly under the speakers .
They come with a box with M6 / M8 and wood screws ( i suppose they supply british and american threads in UK/ USA )
I have 4 footers per speakers but since the footers are height adjustable it works perfect
If you zoom in you can see the principle , the rubber insert on top can be removed .
Reactions: an.vamv
What's the weight of your speakers and what changes in sound did your notice after the introduction of the Cerabase classic?
Track audio solid spike feet.
Hello there,
Thanks
Center Stage. LS 1.5 . No weight intolerance. My speaker weighs over 700 lbs per channel
Reactions: Mr Rickz
I have these brand. Both under speakers auva, and under components, EQ
Here is what I have under my 220 lb. speakers.
ISO Acoustics Titan.
ozzy
Any experience with Nordost Sort Fut under the speakers?
How do you like them? What do you feel they do under the speakers?
How do you like them? What do you feel they do under the speaker?
Hi, Both the Auva for speakers and EQ have the same positive effect on the music. They not only makes music more detailed and musical but they also tighten up what you hear. I really like them.
Thank you,
What material the the AUVA body is made of? Metal, plastic?
Reactions: Magnuska
Thank you,
Actually, I just found that out- machined Aluminum
Reactions: Magnuska
