where to find the "ediscreation" Audiophile Switches
cpasmoi
31
8
13
56
Bonjour
Je recherche des informations sur les interrupteurs et alimentations linéaires audiophile de la marque "ediscréation", mais pas de distributeur en Europe, connaissez vous un distributeur en Chine ainsi que les tarifs car, ils sont d'excellente facture, si membre de ce forum me les avait présenté, j'espère qu'il se reconnaîtra
https://ediscreation.com/product/silent-switch-ocxo/
Merci pour votre avis
cpasmoi
the distributor list in on the website of the manufacturer shows a few EU based distributors, the Swedish distributor website even shows a price tag.
you're right the price refers to a different product...a ripper...
but google brings a review'' well, a mentioning that is showing it's price tag;
This is in Hong Kong $ from Edison’s Hong Kong company.
are you sure? as the currency exchange rate would mean the piece is approx 100 US dollars...looking at it's components used that is impossible.
Ediscreation Silent Switch OCXO ($800 USD) is designed from the ground up to improve the quality of digital music streaming for any streamer, music server, NAS, DAC, digital endpoint, etc. It uses a true audio grade LAN socket for the best signal connection, supports large LAN cable connectors. The core module design with a CNC heat sink provides the best noise shielding and lower working temperature. Silent Switch OCXO uses a built-in OCXO system clock for ultra-low jitter (0.25-0.35ps), frequency stability ±10 ppb phase, and implements discrete circuit designs with linear supply for main power supply and uses ultra-low noise LDO for OCXO clock power.
6,820.00 HKD = 871.64 USD, I believe this is the correct conversion rate.
I had tried to contact the French importer for an Ediscreation switch - they did not even answer.
So I ordered directly at Ediscreation In Hongkong.
My switch arrived in Suisse pretty fast, well packaged, and it even had managed to escape Swiss customs:)
Reactions: Zappadaddy
Do any of you know if there is a North American distributor.
When you go to the Canadian link it just takes you to the parent company in HK.
Thanks
Brad
Reactions: 2ndLiner
Thanks
Brad
Brad
There is no NA distributor. I purchase directly from Edison. He is very responsive. His contact email is: edison@ediscreation.com
Mark
Thank You, Mark.
Brad
