New power amp from Robert Koda with interesting technical solutions.
https://audioexotics.vanillacommunity.com/discussion/13089/robert-koda-s-ground-breaking-amplifier-??-takumi-k160-mono-amplifier
150W / 8 ohm @ less than 1% THD (any mode)
230W / 4 ohm @ less than 1% THD (high power mode)
120W / 2 ohm @ less than 1% THD (high power mode)
Signal to Noise
105.5dB (A weight) @ 1W into 8 ohms. 125.5dB at 100W into 8 ohms
Distortion
0.0009% at 5 watts into 8 ohm, 1KHz.
0.005% at 50 watts into 8 ohm, 1KHz.
Power consumption
550W at all times (high power mode)
400W at all times (normal mode)
Output impedance
0.05 ohms at 1KHz (damping factor is 160)
Input impedance
Greater than 10K ohms (SE, balanced or floating)
Voltage gain (SE, balanced or floating)
26dB
Weight: 45Kg per unit after unpacking
Dimension: 540mm deep 396 wide and 280 high
Signal to Noise
Distortion
Power consumption
Output impedance
Input impedance
26dB
