Luv the Denon. does it sound as good as it looks?
Dear Tango.Dante. These Tedeska carts (https://www.tedeska.com/products/stereo/) models are even more confusing than the vdh. Which one catch your ears most. And where do the stand price wise. Mounting is sme spu?
Kind regards,
Tang
Wow... this is incredible and insane E'' porn...
Wow... really I never hear about this kind of solution. This is totally new for me. Many tks to share this information. I will investigate.Hi Dante,
I am a big fan of Mono, using several carts on the R-80 and other tables.
On the R 80 I am using the first ever built SME with a bakelite EMT OFD-25 playing through a true mono Miyajima SUT enabling matching input and output coils in the best way posssible. Going this path the Mono signal (one side) will be transported on both channels without need pressing the Mono button at the preamp.
a monoraul step up transformer on which you can regulate gain impedance in this way realizing the ideal frequency balance. Stereo is changed to monaural. This is the ultimate Mono-SUT for everyone seriously working with Mono Vinyl especially when you are using true mono carts like the old bakalite monos of EMT and Ortofon.
https://audiocirc.com/2016/07/11/the-first-sme/
View attachment 57419 View attachment 57420
Best
E.
The only place I don't use Kuro to connect equipment to equipment is between 3012R to phono. The original cable works superbly imo. But interested people should be aware that not all second hand 3012R come with original phono cable.
Tang
We both need cartridgeholics anonymous, been aggressively buying vintage mm's for the past several months!
david
I'm still mostly collecting and haven't done much listening but for now the 80's and 90's Technics mm's are my favorite.David,
What's your current favorite vintage MM? I've been enjoying my NOS Signet TK-7SU a lot lately.
david
Favorite models?
I'm a classical music fan and really I love to listen to string instruments -violin, cello, etc...- and dark german lieders in mono LPs.
During long time I have used different vintage SPU mono carts with 6 or 7 grams of weight... I can see that you are really mono fanatic.
And which kind of Phono EQ are you using? Original EMT 139 maybe??
But not with every cartridge ! There are still matching issues to consider.Dante, I have two 139 Monos (with some new caps) built together.
With the Miyajima trans you can do true Mono with every phono preamp.
Best
E.
https://audiocirc.com/2018/04/27/reducing-noise/
david
(...) Nothing more interesting than that chapter. You can improve your phono chains by using and understanding the right transformer matching.
Best
E.
IME the only way to know is by listening, I have over 30 SUT's of various vintages and sources and I never found any commonality in sound between the numbers and the outcome. Even buying a cartridge manufacturer's supposedly matching SUT is a guarantee and more often than not they sound worse than the generic one in my phono stages, at least to my ears. The most success I've had is having custom SUTs built for some of my favorite or hard to match cartridges.Yes, but in the end you have to use your ears or measurement instruments and test LPs - in general manufacturers do not supply us technical information enough to match a cartridge to a transformer.
