While the correct tracking force for any particular cartridge should not damage the groove, assuming that there is no mistracking, IME a far more damaging aspect is the actual design of the diamond. This becomes evident ONLY upon play with a different stylus shape that is able to sit in the wall at a different angle. Some of the old elliptical/conical shapes are seemingly fine while playing ...unfortunately only when a more modern shape is utilized is the damage then evident...and the sound is clearly distorted on the record at that point!
It might be good to remember that there is always a certain cutting aspect to the shape of the stylus in the groove...even though this is very minimal...we usually call this record wear. Through extended plays, the more the groove is in fact damaged...even under the best of circumstances....
Personally, this is a reason why I like to keep multiple copies of the albums that I listen to the most. My preferred play copy and my reserve, for maximum SQ.
Would i use one of the older stylus shapes on my better vinyl...again personally, NO.
