I said I would never buy another Turntable...Argh !!!
David estimates his stand for the AS2000 weighs 1000lbs. Since renovations are ongoing, I added a support beam under the stereo equipment area. It’s now rated for 30,000lbs. :D
That's why we call you ROCKITMAN!:D
david
We start lagging behind you David with our 340kg...not good ;)
Is it solid steel including the legs (if you can share)?
Cheers,
Cheers,
Your rack is asian size Jarek. They are american.
Cheers,
Hi Jarek,
Yes it's all solid steel, just getting the finishing and paint of the first ones done, should have pictures in a week or so. The total is heavy but it breaks down to manageable size for two to assemble.
David
Well, the structure we are cooking right now will be truly American then ;)
Have you been able to move the rack?
Cheers,
I can move it with my pinky Jarek. (We have to bluff David a little here :))
Tang
Hi Jarek,
David
Looking forward to see it David. I'm sure it will be something (but called nothing hahaha!)
Cheers,
Cheers,
It’s called The Nothing because it’s designed to do absolutely nothing to the sound. It won’t extend the bass, won’t contrive a fake soundstage, no special imaging tricks or any addatatives to the sound, you’ll hear the system and what’s there in the recording and Nothing more.
david
david
We should have called Stacore Nothingcore then ;)
Hmm, “Nothing” suggests SOMETHING more than “nothing”
Hi Jarek,
Yes it's all solid steel, just getting the finishing and paint of the first ones done . . .
David
Hi David!
Have you decided, then, that the finish of the Nothing stand will not be natural stainless steel to match the turntable?
Hi David!
Black actually makes good contrast and AS stands out more Ron. Trade off is scratches..even when industrial paint is used.
But don’t use black. I want to look good by myself.
Tang
Hi David!
The building blocks of the rack have the exact same silk shimmer finish as the AS-2000, you can order the shelves in both black and stainless.
david
