help me find a good CD burner program
joeling
177
51
335
Hi,
I have basically regressed from file as source playback to CD player playback. Problem is that some of the original CDs can no longer be located. Therefore, I need to burn some ripped albums to disc. Can anyone suggest a good CD burning program ?
Much appreciated.
Regards,
Joe Ling
joeling
177
51
335
Thank !
Empirical Audio
1,169
207
150
Great Pacific Northwest
www.empiricalaudio.com
If you are not using a reclocker on your transport, make sure that you use good media to reduce jitter. I recommend Mitsui Audio Master. Also, make sure you treat the disks before you write them with a good treatment.
Steve N.
Empirical Audio
joeling
177
51
335
Dear Steve,
Thanks for the advice. My transport is fed by wordclock from a master clock in turn fed by a reference clock :eek::eek::eek:
Regards,
Joe Ling
Empirical Audio
1,169
207
150
Dear Steve,
Regards,
Joe Ling
That will certainly help, but if you can change coax cables and it changes the sound from your DAC, then a reclocker or the Mitsui Gold Audio Master will still help. Do the experiment.
Steve N.
Empirical Audio
LL21
14,430
2,519
1,448
Dear Steve,
Regards,
Joe Ling
Hi Joe...was just reading your signature...did you ever end up with a final decision on your amplification? Are you running the Gryphon Mephisto?
