Dispelling ground myths
Speedskater
941
15
368
Cleveland Ohio
They also will likely tell you nothing about AC voltage as multimeters are very limited in the frequency range for which they can give an accurate ac measurement
So who said anything about using a cheap multi-meter?
With good modern test equipment, making measurements at -120 to -130 dB's is common.
You measure the signal to noise ratio at the loudspeaker terminals.
Measurements done by skilled engineers/scientists using the correct test equipment for the task at hand.
jkeny
Industry Expert, Member Sponsor
Feb 9, 2012
3,374
42
383
Ireland
Folsom mentioned using a multimeter - maybe you or he can you give some examples of multimeters with a relevant accurate measurement across the frequency range we may be interested in?
That would be great - can you give us an example of SNR measurement differences at speaker terminals which show a difference in noise that RogerD is perceiving as audibly improved sound as a result his PEC techniques?
RogerD
3,734
319
565
BiggestLittleCity
I had a similar conversation with Don Herman about chassis grounding...aka PEC
"Same principles apply to controlling noise currents/voltages on the ground/shield paths.
Chassis grounding in audio is no different than for any other circuit sensitive to noise. Keeping a good chassis ground relatively independent of signal ground can do anything from nothing to profound improvements in the noise floor depending on the circuit design and implementation. You generally want the "noise" path to ground to be different than the signal return path, and often that means a heavy chassis ground to provide the lowest impedance path for noise while the signal return goes through the signal cables.
strap everything so all ground noise is common-mode
, then shielded cables for low-level signals and only low-impedance (e.g. speaker) or isolated (e.g. power) connections should control noise for the vast majority of folk.
Like many things, conceptually simple, straight-forward good engineering practice, but not well known or recognized and can be unexpectedly difficult to implement well. There are numerous texts and courses teaching noise control."
Don Herman
jkeny
Feb 9, 2012
3,374
42
383
Ireland
I'd expect broadband AC noise from 60 Hz on up. Possible sources are induced ground loops, leakage currents, local emf...
It seems obvious that certain substances can actually serve as a "sink" for noise. Silicon carbide, quartz, tourmaline and carbon, probably many more. Hearing what a Furutech GTX receptacle sounds like in regular vs NCF versions is astounding...
It's not obvious to me how "Silicon carbide, quartz, tourmaline and carbon" act a a sink for electrical noise?
Speedskater
941
15
368
Cleveland Ohio
Are you a skilled scientist/engineer? It's not about the tools, it's about how the craftsman uses the tools.
How would I know what RogerD heard?
The measurements and the listening test need to be done on the same setup at the same time. But if the noise measurement differences are great enough, you might not need to do the listening test.
jkeny
Feb 9, 2012
3,374
42
383
Ireland
Part of being skilled is knowing what tools are not suitable due to their limitations & a multimeter is just not suitable for doing what was suggested
I expect by his reports of the audible improvements.
I agree but the opposite also applies - if listening reveals audible changes which measurement doesn't you may discount the measurements as using inappropriate equipment or techniques to reveal what is audible
Speedskater
941
15
368
Cleveland Ohio
A person with skill would not need to ask that question.
How can we test his situation, without testing his situation?
Then we need to find a person with greater skill or get the correct test equipment. Because there will be measurable differences.
jkeny
Feb 9, 2012
3,374
42
383
Ireland
I was pointing out that a multimeter is not suitable measurement device for this application as Folsom seemed to suggest - I asked for an example of such a multimeter measurement if this was under dispute.
You specifically stated that a multimeter could be usefully used
Yep it is. Common Impedance Coupling noise is when two chassis are at different leakage current potentials and use the interconnect shields to equalize. So short Safety Ground wires or chassis-to-chassis PEC wires wire reduce the leakage potentials.
More likely measurements will reveal problems the are not easily audible.
So when you talk about "More likely measurements will reveal problems the are not easily audible." you include this in the same post as suggesting using a multimeter.
You mean test his reports of audibility?
Right & as I asked before to back up your claim but I'll change my request slightly as you focused on a particular aspect that avoids answering "That would be great - can you give us an example of SNR measurement differences at speaker terminals which show a difference in noise" which shows a change due to PEC being applied? Not something which is a ground loop hum or buzz - these are gross intrusion of electrical noise into signal ground.
I mentioned RogerD's reports specifically as he did not hear any ground loop hum or buzz prior to his beginning this PEC technique.
Just a question - do you believe that there are other audible effects from such electrical noise intrusion into signal grounds, besides the typical hum & buzz?
4,704
These materials are known for its high microwave absorption - it is why I always unsuccessfully ask for a rigorous specification of bandwidth when debating noise ...
jkeny
Feb 9, 2012
3,374
42
383
Ireland
Ok, yes I agree electrical noise needs to be characterised as regards spectrum, amplitude & temporal aspects & not treated as one amorphous blob
4,704
Part of being skilled is knowing what tools are not suitable due to their limitations & a multimeter is just not suitable for doing what was suggested (...)
+1!
IMHO you need an audio frequency and an wide band spectrometer (-200 MHz) with differential input to properly carry these measurements.
I regularly use a RTA to optimize cable layout in my system , particularly when using single ended electronics and moving coil cartridges.
DaveC
3,899
2,143
495
Something to look into then. I don't have any info for you as I haven't done any testing or measuring yet besides hearing other companies products, but it's very obvious in a simple subjective listening test of something like the Furutech NCF parts vs the non-NCF parts where the main difference is the addition of tourmaline powder. There are many other companies putting out products that use piezoelectric materials to attenuate noise as well.
And just because I don't specify frequencies doesn't mean it's "one amorphous blob", I simply haven't done any testing to know the specifics. One member here did use a handheld AC power quality meter that showed the Furutech NCF receptacle reduced noise significantly. Some of us have observed through listening that it reduces noise and distortion. It's not subtle either.
We've had 7 pages of leading questions now... enough I think? ;)
jkeny
Feb 9, 2012
3,374
42
383
Ireland
Yea but the ~5dB rise in noise floor (& some spikes) shown in your plots are down at -130dB & typically dismissed as inaudible.
Are you just showing these plots as an exercise in engineering or as something that is audible?
jkeny
Feb 9, 2012
3,374
42
383
Ireland
I will read about the NCF parts, thanks
Didn't mean to accuse you of anything - sorry if it came across like that - just a general point that noise is often just a term used as a general category without recognising that it has specific characteristics
What do you mean by the part I bolded?
4,704
(...) One member here did use a handheld AC power quality meter that showed the Furutech NCF receptacle reduced noise significantly (...)
Do you remember what was this meter?
4,704
Yes, probably inaudible but I felt proud to have achieved such low noise hum.
It was surely as an exercise in very amateur audio engineering, but my point is that people probably could easily complement their points with measurements not just with hyperbolic subjective statements.
DaveC
3,899
2,143
495
Well, you started out by showing the path of least impedance for return currents on a pcb's ground plane and asking specific questions about the characteristics of noise so I figured there gotta be some main point you're getting to?
DaveC
3,899
2,143
495
Alas, I still have limited equipment to make such measurements... right now Omnimic, DATS and a nice Kiethley multimeter... but do plan on buying an o-scope and signal gen in the near future. Maybe we need a new thread on recommended equipment for analyzing audio systems?
I do not remember which meter was used for the NCF test.
jkeny
Feb 9, 2012
3,374
42
383
Ireland
I showed the different preferred paths for different frequency return currents on a pcb to illustrate the principles that apply. When we consider cables where is the path of least that impedance - is it the shield, the ground wire or one of the signal wires? What about cable construction - how does it affect the return current path? What about skin effects?
The main point is that ground currents & ground returns are not simple matters & I was hoping this thread could focus on matters.
jkeny
Feb 9, 2012
3,374
42
383
Ireland
Ok I wasn't aware of these high quality DMMs - thanks for correcting me
