DLNA is a subset of UPNP, with more restrictions, DRM, etc. In practice, it's the same thing.
That's not truly the case. UPNP is a specific to device - sharing over a network(s), DLNA is specific to sharing content (more device agnostic).
The Trinity server is a Windows 10 system with 10TB HDD and an additional SSD for the operation system and software.
OK, I have reached Dietmar for a support, who walked me through the setup.
As it turned out - it is a very straightforward process. It is even easier to setup than Aurender - no small feat. Once powered on, the PC&Drive creates its own WiFi network, so all you have to do is to download an app on an iPad, connect to that network and you are ready to go.
No local WiFi or wired Etherned connection are even necessery. The Trinity system is basicly self contained.
You probably could from technical point of view - the current versions are NUC i5 based (among other improvements in PSU department), so are quite powerful in terms of computing power - many times faster than Aurenders. You could probably even install Roon + HQP on them, although in that case I think it would be best to install an SSD instead of the 6TB starage HDD (for faster Roon access speeds) and have your music on an external NAS drive.
The Windows system is 'locked' somehow, meaning that many things seem to be switched off and do not work as expected - it seems Dietmar wanted to limit the possibilities for the user to mess around (which is a wise strategy for a manufacturer). To use it with my lampi for comparative purposes I would need to install the Amanero driver - something I do not want risk doing.
i5 won't be snuff to do very high rate up sampling if both Roon and HQP are used.You probably could from technical point of view - the current versions are NUC i5 based (among other improvements in PSU department), so are quite powerful in terms of computing power - many times faster than Aurenders. You could probably even install Roon + HQP on them, although in that case I think it would be best to install an SSD instead of the 6TB starage HDD (for faster Roon access speeds) and have your music on an external NAS drive.
I can do DSD 256 upsampling on my i5 no problem, so DSD 512 upsampling with -2 filters should work too. All is very academic though, as I seriously doubt that someone will use the PC&Drive with a different DAC than the Trinity, which will only need PCM upsampling. For that, the i5 CPU is actually much more powerful than necessary.
Please do. The W20 sounds much better. The old S10 isn't any better than a regular computer when using it via its USB out.
In my experience, the USB signal quality makes a big difference with this DAC.
Central external PSU, for the upcoming Golden Reference Series .
Jazzhead,
so does this power supply boost the Trinity dac performance too?
and is that then considered an upgrade to 'Golden Reference Series' level for the Trinity dac? or would there be other changes to the dac planned too to raise it to that 'Golden' level?
thanks.
Mike ,
Of what I know ..... there will be a redesign to the control unit as well, in order to elevate it to Golden Reference Standard . Plus some added gold bling to the front panel ,of which I probably will not be a fan . The GR phono and pre will be ready for the upcoming AE show next month, along with the new Media PC / transport . Not sure as to when the GR DAC will be conceived .
Cheers.
thank you.
will the GR version be able to do higher resolutions natively, dxd 352 and 384?
any mention of provisions for dsd?
