A better visualization is to display all CPUs.
You will probably see that a general average 40-50% utilization may correspond to 80-90% utilization on the real cores, which of course would be pretty high.
Right. That's why I posted a photo showing all 8 cores
Maybe the photo is not very clear. The first four charts on the left are physical cores, the four on the right are hyperthreaded. As you can see, they all are on average around 50% utilization.
IIRC, you want to not use hyperthreading for the best sound if possible. BUT one should have about 20-30% utilization with hyperthreading off, according to the designer IIRC.
Obviously you can use this chip. But is it the best choice and is it the best for someone who is looking to get started.
As an example, Jussi of HQP, is always looking to push the envelope in his code and at times it can be very processing intensive, like his xtr. That is one reason why he come up with the 2s variants. They are less intensive then the non 2s version and they allow most to utilize that filter.
So it is wise to have a little head room.
Also you mention that your fan ramps up when you are using the xtr-2s, That is because the chip is around its max and needs a lot more cooling. Fine for a short burst but not designed to run that high for very long periods. So could be a shorter chip life.
