Thanks Amir.
Appreciate that
You guys are too polite. There has to be a sanction for that in the ToS some place....
Thanks Amir.
Appreciate that
I know what the Intona does & how it does it - I also know it's design weaknesses for it's role in audio (which it was never designed for) - you obviously don't
No misunderstanding on my part - but I see ample evidence of your claims which you now try to deny "if these boxes are genuinely creating benefit due to improving the "grounding" of your system then yes there quite obviously is something deficient in its grounding regime." and later "if it is a problem in your system then use cheap cable to link the units. An expensive box with bent bits of copper and kitty litter inside is totally unnecessary and certainly less effective."
Can you adjust it, and then compare?
That's assuming it's a grounding issue. I'm not convinced that it is.
Have you ever heard of noise appearing near the signal outputs in an unbalanced audio system, at all?
Noise that shouldn't be there in the first place?
Call it 'grounding' if you prefer because technically it may not be proper terminology but it appears it is quite analogous to how grounding works.
I think the problem is most of the guys experiencing the performance gains are using single ended connections.
I think the problem is most of the guys experiencing the performance gains are using single ended connections. The highest priced gear isn't balanced. Too expensive to implement.
so trying to limit the Entreq or grounding improvements to single ended environments is a non starter in my experience.
2 points.
maybe the designers found that at the top of the food chain many times (not always) single ended sounded better.....when that is the result of their investigation.
and how much 'highest priced gear' have you heard to infer that it's better balanced? pardon me if I'm misunderstanding the point you are making.
I don't really care one way or the other about balanced or not....and have no dog in that fight. I'm for whatever sounds best for particular gear and systems. my personal experience is that single ended generally seems closer to the real music to my ears. but that is simply what I've been exposed to.
only someone designing a particular circuit and that has the opportunity to design it both ways, single ended and balanced, and then compare, can say for sure which is better. you cannot remove the circuit context from the interconnect geometry.
and for what it's worth; in my system the fully balanced Trinity dac with XLR Tara Labs Grandmaster interconnects, the cable grounding and the Entreq are both very effective and the result was astonishing. so trying to limit the Entreq or grounding improvements to single ended environments is a non starter in my experience.
2 points.
Speaker cables radiate the most.
Mike would you be kind as to connect your entreq on the front of your appliances instead of rear? Also does placement matter? What happens if it's centered in front of stereo, or if it's off to either side, any difference?
Well the problem is it costs near twice as much for the internal boards to make a proper fully balanced system. This is why you see lots of products offer single ends only options. It's not because single ended improves performance, or balanced degrades performance.
I have been playing around with both single ended and balanced in my own system and find the balanced to be superior for the many obvious well known reasons.
Did you compare the Entreq boxes to a proper star grounding setup with copper stakes pounded into the ground yet?
It's more a case of 'more likely' rather than 'limit'ing IMO.
and you know that 'lots of products offer single ends only options' due to cost......how do you know that? have you spoken to designers of high priced products and they have told you that? or are you assuming that? I'm not saying you are wrong, only wondering whether your point is a guess or do you actually know?
my perspective is that you are connecting a few too many dots without really knowing.
no; I've not done any experimentation with that. and have no plans to. OTOH my Equi=tech 10WQ 10kva isolation transformer wall panel system has it's own grounding rod in the ground right outside my room; and all the gear that is plugged into my power grid is grounded into that. so I'm already enjoying the benefits of that to begin with.
I know this because I know how these products are built, and what goes into building a balanced system vs a single ended system. You need to double most of the parts up. Why do you think products that have both options always charge more for the balanced versions?
So you're only using a single ground rod? Maybe you should try a true star ground system. I bet you can find someone who would set that up for you at a cost probably 20x less than what you have into all of your grounding boxes.
I also bet a simple $100 USB interface board upgrade in your GG would be more beneficial than all of your grounding boxes combined as well. You must have over $100000 into all these boxes alone.
Has anyone ever tried out these? Seems a bit more cost effective:
http://audiosensibility.com/blog/products-2/grounding-devices-2/
sorry; a general familiarity about how things are built is a different thing than reading the mind of a high end audio designer. but I can see you have a strong grip on your omnipotence on this issue so i'll just withdraw from further discussion about it.
thank you for the suggestion.
