Vivid Giya G3
wisnon
3,536
640
1,200
I wonder why the hot girl in the picture:p faces away from the seated position?
LoL
I didnt actually hear THOSE Aplogues …yet. The pair I heard were all black and were the Mk1…These gray ones are Mk2 and are reputedly notches above!
Costviewer
4
dallasjustice,
Congratulations on those fantastic speakers! You've made an excellent choice!
It is interesting to see how many different sub/non-sub recipes each one of us has come up with. I used to swear by good sub. Since I've had G2 SAM-ed I no longer need to augment the sound with Velodyne DD12+. Simply because I cannot hear/feel any difference, let alone Velodyne bass is simply slower and more 'woolly', I'd say. I play music in a relatively large room (approx. 45 sq m) and yet bass from Vivids is simply amazing. I'm sure my neighbours could attest that too... :)
bonzo75
22,647
13,683
2,710
London
bonzo75
22,647
13,683
2,710
London
A guy who owns the Apologues bought the Tune Audio Anima horns - 30k compared to 120k or so. They sit in the same room, next to each other. He also has a Goldmund reference TT, the old amps, and the CDP. He listens to only Anima now. Track for track, I preferred the Anima.
Stenheims are good, for a cone speaker. But this is DJ's Vivid G3 thread. Good stuff Michael.
Audiophile Bill
4,293
4,093
675
Anima powered by Devialet!
Al M.
8,801
4,550
1,213
Greater Boston
80hz is the highest frequency at which bass cannot be localized. Floyd Toole talks about this in his book. Mono subs offer the smoothest bass response. I've measured many different ways (various crossovers and mono versus stereo) I set my subs up the way Toole describes in his book for a system with two subs. It works very well and the subs cannot be localized. The stereo image remains perfectly intact.
Interesting that you set the crossover so high. My sub's crossover point is set at 41 Hz, which is a "rolloff frequency" with a shallow slope past the crossover point, with subs rolling in while the main speakers, which are minimonitors, fade out (bass is perceived to be linear, both by me and by others). My subwoofer is located more towards the left hand rear corner of the room, but bass is often in the right channel (stand-up bass in jazz, contrabasses in orchestral music). All the frequencies of the bass appear to emanate from where the instrument is located in the stereo mix, with the imaging being a coherent whole from top to bottom; the sub is absolutely not localizable in this set-up as well.
wisnon
3,536
640
1,200
Apologues Mk2 are minimum $600K a pair (fully active/wireless/DRC time aligned and room corrected by Proteus/Leonardo software)! This is another guy and he listenes only to this system and averages 5 hours a day. Your guy likely has the older Epilogues. AFAIK, only 25 Apologues will ever be made.
I am just yanking DJs chain. Of course his speakers are fabulous!
Audiophile Bill
4,293
4,093
675
Hi DJ,
Just curious from an educational standpoint - if you are crossing over @ 80hz in the digital domain, I assume that means your Vivid speakers are not receiving any musical content below 80hz? In which case, why would you not buy some monitors instead as surely you are wasting money buying a full range speaker if the bass drivers are totally redundant?
Interesting question. Many people will say that the amp will drive the speaker much easier. I am like you however. I run my speakers full range and use a pair of Fathom F113's to bring up the bottom end crossing out everything above 41 Hz using the crossover on the Fathom . My subs are totally invisible in the room as to where the sound is emanating from.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Hi DJ,
Not speaking for DJ, but if you cross over @ 80Hz, the sound doesn't automatically cut off there. Depending on the slope, the sound could just be 3-6dB down an octave at 40Hz.
If you're using a steeper slope, it could be 12-24dB down per octave, but the steeper the slope, the more problems you run into.
Audiophile Bill
4,293
4,093
675
That makes sense to me, Steve. I get why Dallas would do what he does also but don't then see the point of going down that route with a full range.
Audiophile Bill
4,293
4,093
675
Aha - thanks, Bruce. I has assumed he would use a very steep crossover in the digital domain.
Audiophile Bill
4,293
4,093
675
dallasjustice
2,067
8
Dallas, Texas
Something like the Acourate crossover as seen halfway down the page in this article:
http://www.computeraudiophile.com/c...e-alignment-driver-linearization-walkthrough/
The crossover I use is a two octave linear phase crossover. It is important that the speaker be able to reproduce bass below the crossover.
You can see the crossover and impulse response for the crossover in this thread:
http://www.whatsbestforum.com/showthread.php?16922-Subwoofer-2-2-vs-2-1-REW-measurements
Audiophile Bill
4,293
4,093
675
Ah thanks. Unfortunately since the x axis is not labelled at regular intervals it is hard for me to see how much bass output is occurs when the amplitude drops to -12, -20db etc. What does 2 octaves down from 80hz take you to?
4,702
Bruce,
Even considering this factor, one could think that a G1, a G2, a G3 or a G4 should sound the same crossed at 80 Hz - they share the same mediums and tweeter and use the same techniques in bass units.
dallasjustice
2,067
8
Dallas, Texas
Bruce,
I think the G4 has something else different from the others. I could be wrong about that. I do notice that the crossover points are a little different with the G4 than the others. But, yes, that was part of my thinking when I selected the G3.
Rodney Gold
983
11
18
Cape Town South Africa
Bass and Dynamics go hand-and-hand. Two necessary conditions for big dynamics are (1) close to flat low frequency content down to 20hz at seated position and (2) speakers which can do low distortion at high SPLs over the entire bandwidth.
I definitely do not do flat at seated position , I apply a house curve .
This is one of the target curves I use as an example
