The best phono stage on the market is the TENOR PHONO 1.
Nope.
We are finally going to offer a stand-alone after all these years (the MP-1 was introduced in 1989 so its been a while). This is mostly because customers are asking for it, not because we think it will be better. We've been offering line stages since 1996.
I guess you never heard one
I own the tenor, I listen to a lot of phonos but all my equipment is tenorNo, just like you, we've never heard every high-end phono stage
The most impressed I've ever been with a phono stage has been the Soulution linestage/phono. The fact that it was built in could have a lot to do with it.
The best we have heard so far is Qualia Indigo Series Three Chassis Mono Block Phono Amplifier.
The three phono's I would like to hear against my current reference...the Lamm LP1 Signiture, the ARC REF 10 and the Pass XS to give SS a chance to get back into the system.
Edit...I would want to hear the Doshi phono too....
Johan, your website link doesn't work.
Interesting! I had both (darTZeel and Soulution) in my system at the same time... darTZeel was better (and cheaper)
I guess the battery thing does make a difference, as Mike L put it so well...
Well then perhaps I will like the dartZeel. If you ever get the new model, let me know!
1 owner seems to prefer Simaudio phono to the built in phono of Soulution top preThe most impressed I've ever been with a phono stage has been the Soulution linestage/phono. The fact that it was built in could have a lot to do with it.
I don't think there is one best phono stage...choose your preferred topology and select from that handful of statement products. It will be a matter of listening preference/taste and system synergy.
Ah- that is a matter of debate!
IMO a phono section is best off housed within the chassis with the line stage. The reason is connectivity- its the job of the line stage to control the interconnect cable, and whatever circuitry it uses to do that will have to be housed with the phono section if the phono section is a stand-alone unit. Further, the mechanical connections that have to exist at the output of the phono section to the input of the line stage simply cannot compete with hardwired connections. This phenomena is extremely audible and is why we've never offered a stand-alone phono stage. Put in a nutshell you simply can't get them to sound as good.
The usual argument for an external phono section has to do with power supplies, but the fact of the matter is that preamp power supplies do not have nearly the issues with noise and crosstalk that are issues with integrated amps and stereo power amps! Preamps often have regulated power supplies or heavily bypassed supplies so crosstalk noise isn't a problem if the design is at all competent.
Now a reason for having a stand-alone unit anyway is if the unit has EQ settings for non-RIAA curves (perhaps including tape EQs) and thus also has a variety of inputs for different cartridges perhaps on multiple turntables. These things require some real estate that might take up quite a lot of space in a chassis. But if you are only playing stereo records than this is not a concern as they all have the same RIAA curve.
I think the message here is that you're probably not that objective.
