Best power cord for DarTZeel?
4,704
Transparent Audio MM2 power cables are an excellent match with the DartZeel NH108 in my system.
Any reason for not going with Stealth cables, specially considering you already have a few of their PC´s?
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
+1 on the Transparent MM2s.
On my system(s), the KS Elation was as good as the MM2s, but without the grunge that the MM2s tend to add on top. So I ended up with the KS. But on your system, the MM2s might be just the ticket.
flez007
2,915
36
435
Mexico City
I have both the KS Elation and Echole Obsession Signature, both worked great with my Lamm amps but preferred the Echole option at the end.
amiglick
22
I'll try.
The mids and the highs were lean and the overall sound was "closed", not enough airy.
Thanks.
amiglick
22
It is a bit more complicated.
Stealth Audio has 3 types of power cables: Digital, Pre and Power.
The first 2, works extremely well in my system for more than 2 years.
About a year ago I purchased the Power PC and it did'nt work as well as the other 2.
I will give a try to Transparent.
Billy Shears
255
1
150
Stealth now have the Uni Pwercord you can configure yourself.
They also make the M7000 if you are looking for a "airy soundstage" then this may be a option..... Best ask Serguei
PS. This is also quite new:
http://www.stealthaudiocables.com/products/Straight_AC/straightAC.htm
maslak34
Stage 3 concepts kraken is by far the best..
amiglick
22
I finally settled on Stealth Dream POWER cable.
Very pleased with the results.
Thank you all.
