Has anybody tried the SHM Platinum series CD's ? They are supposed to be a flat transfer , no processing , compression , noise shaping etc from the original analogue master tape . Wonder if they are worth the extra ...
Andre thanks , have put in an order for a few ... Will update once done listening .. Cheers
As far as I know, the only available SACD of the Aja album is SHM from Japan. It's good but to be perfectly honest my 1978 LP sounds better...right Mark?
Great titles. I have the Queen and Dire Straits ones too.
FYI, I have not been impressed by the BluRay spec discs.
You mean those Pure Audio BD's? What is it that you're not impressed with?
No, those are very good!!!! I have about a dozen. I meant the BluRay Spec Redbook CDs from Japan.
What was is it with the BlueRay discs that didn't hit the spot ? Not an upgrade from regular RBCD then ?
A RedBook CD is a RedBook CD. The only differences you'll find is the mastering and/or how the transport handles the data.
Don't forget the Glass CD . 1000 bucks or so a pop .
They are called Blu-Spec CD, not BluRay spec.
Yes, thanks for correction. Isn't their some variant called Blu-Spec HQ?
