MSB Diamond DAC IV Reviewed By Stereophile
Priaptor
929
19
FL
It is designed & made by the Swiss branch of ReQuest Audio so shall not be cheap!
Maybe Wizard can have some info on its price.
The current model looks simpler than the prototype shown in hifi shows last year.
The prototype in Swiss ReQuest Audio website seems to be for home theatre use: http://www.requestaudio.com/index.php?id=77
Thanks. Well maybe one day we will see a ProI2S server solution DIRECT from MSB.
Elberoth
2,011
259
1,170
Poland
I will try to post it tomorrow. I using my iPad now.
Young Skywalker
125
82
935
47
Could be a lot closer than one might imagine. ;)
Priaptor
929
19
FL
Bassfeen
4
Asia
May the Force be with you young Luke
When someone pay 40,000 Plus for a DAC I would always assume the parts are already hand selected and measures best. Only to find out another 20 Grand at a price tag of 60K US for hand selected parts is starting to get silly. So that leaves all those who order the standard Diamond DAC with less inferior parts and components compared to the select Series. Something to wander upon.
audioblazer
766
208
1,605
Malaysia
Bassfeen, I agree with u. I just got mine a month ago & I would expect the parts to be excellent but its seems it is not true.
Bassfeen
4
Asia
Bassfeen, I agree with u. I just got mine a month ago & I would expect the parts to be excellent but it's seems it's not true.
Im sorry to hear that, from what I can tell you might have ended up with parts which don't measure so well. As the ones which measure well in stock are reserved for higher paying clients in the 60 Grand Region Select Series. Its a shame MSB had to go down this path and splutter it out all over there site. Makes you think a 40,000 Grand DAC is not using the best parts MSB can source is a dam Shame.
CKKeung
3,063
3,201
1,410
Hong Kong
I am able to get some photo of "The Beast" at the Munich Show 2013 :
The Beast at Munich 2013 e.jpg The Beast at Munich 2013 c.jpg The Beast at Munich 2013 d.jpg The Beast at Munich 2013 a.jpg
Elberoth
2,011
259
1,170
Poland
Thanks CKKeung,
Those photos are much better than the one I've taken with my phone. As you can see, the board looks very pedestrain next to the DAC IV board.
Elberoth
2,011
259
1,170
Poland
Let's wait for the press release. Now its just speculation.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
The way to look at it is this. Let's say 90% of galaxy clocks are within +/- XX percent of accuracy specs. The five percent that is below the accuracy range gets rejected, and the 5% that is above accuracy range makes it into the "select" series. this does not mean the clock going into a standard Diamond is not "excellent".
Elberoth
2,011
259
1,170
Poland
we do not know what the changes are, so les't just not speculate.
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
The site is pretty clear:
Includes hand selected Galaxy Femtosecond Clock
Includes hand selected Diamond DAC modules
Includes our best USB input module
Includes hand selected volume modules
Includes a select Diamond Power Base with reduced noise (no transport supply)
They just selected the core components with most impact on sound quality and picked the outliers in the performance range. The only thing that could potentially have a change in design in the select Diamond power base. I have a hunch they just eliminated the transport supply to be able to position it as a "different" powerbase.
Elberoth
2,011
259
1,170
Poland
OK, thanks, haven't noticed that info. How much is the new DAC in retail ?
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
It is $60K, but this includes a bunch of options, the powerbase and galaxy clock. You'd have to do the math to find out how much premium you're really paying over a standard diamond with the same options. I suspect around $15K.
CKKeung
3,063
3,201
1,410
Hong Kong
IMHO This list of 'improvements' mentioned in MSB website is hard to convince audiophiles that the USD20k increase in price is justified.
Will there be a MSB demo in CES that a Diamond Select is compared directly with an usual Diamond IV Plus (with Galaxy clock & 384USB) to demonstrate the superiority of the former?
Does MSB dare doing such a shootout in open?
Elberoth
2,011
259
1,170
Poland
IMO that will be the task for the dealers. If it doesn't sound any better, then they will probably not sell many.
My math may be a bit rusty, but I belive the price difference is $15k for the similarly equipped DAC IV Diamond, which sells for $45k.
CKKeung
3,063
3,201
1,410
Hong Kong
Hi Adam,
The Diamond Select has the Galaxy clock & Signature384 USB onboard.
Therefore, for a similarly loaded Diamond IV Plus : 27995 + 5995(Diamond powerbase) + 4955(Galaxy clock upgrade) + 1395(Signature384 USB) = US$40340
http://www.msbtech.com/products/dac4diamondDetail.php?Page=platinumHome
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Hi Adam,
It also has the volume control option and the new heatsinks are also an option, so it is a little more than that. Why they would bundle it with the USB when they are positioning streaming through the UMT+ as the best way to do computer audio is a bit of a puzzle to me.
CKKeung
3,063
3,201
1,410
Hong Kong
Thanks edorr,
A fully loaded Diamond IV Plus : 27995 + 5995(Diamond powerbase) + 4955(Galaxy clock upgrade) + 1395(Signature384 USB) + 2995(volume control)= US$43335.
