Artisan Fidelity "Achates Idler Drive" Turntable
MylesBAstor
81
1,725
New York City
These drives are often mistaken for one another due to their obvious similarities, as they both couple a spinning "rim" of sorts to accomplish the end goal, it can be confusing at times to discern between them. :)
The difference lies in the mechanical component coupling, whereas the rim drive couples the motor directly to the platter periphery by means of direct motor to rotating spindle contact, the idler drive couples the rotating motor spindle to a passive rubberized wheel which once engaged provides the rotational force and simultaneous secondary point of contact at the platter side which sends the platter into motion.
Chris, the VPI rim drive is decoupled from the twin motors and in addition, also acts as a flywheel.
Christopher T
75
13
315
www.artisanfidelity.com
Myles, Yes, a keen observation, traditionally, in my view this layout would be considered an idler drive but in this instance referred to as rim drive, perhaps the idler connotation was simply not preferable to the designer. "You say tomato I say tomahto...." :b
MylesBAstor
81
1,725
New York City
The Lenco design didn't go unnoticed -- and in fact, the sound of which, inspired Harry Weisfeld to build his "version." :) And the sonic differences between the belt and rim drives are very pronounced.
Christopher T
75
13
315
But do they use them on Lencos or Garrads?
Worldcat, To the best of my knowledge, we are the first to design a modern precision inverted bearing solution for the Garrard 301 and Lenco L75 platforms.
Christopher T
75
13
315
Do you have pictures of the table itself? With the inverted bearing.
Worldcat, Nothing official yet by way of photographs but here is a sneak peak.
Christopher T
75
13
315
Also, See below regarding the PM about the Achates inverted CNC platter underside. IMG_6304 1200 webcopy.JPG
Worldcat
142
That is a serious platter! I wonder if it sounds as good as it looks, would/could be amazing.
Christopher T
75
13
315
Lin, Shown is the bead blasted option for Achates inverted modular platter - finish African Padauk
First production run is nearly finished.
Christopher T
75
13
315
Christopher T
75
13
315
Bruce, thanks.
World's first inverted modular bearing/platter design based on the legendary Swiss Lenco L75 idler drive geometry.
Entire line of modular platter upper material substitutions to be announced.
MylesBAstor
81
1,725
New York City
Better looking than any digital piece I've ever seen too! :)
mep
17
Can someone please explain to me how copper makes a good interface for a record to sit on??
Worldcat
142
Copper will give it more damping. It will be a matter of choice on which platter one would like best, be it copper, aluminum, stainless, and or magnesium to name a few. If you notice the two screw holes on top i believe that platter (top plate) will be interchangeable. You will have to ask Chris more on the topic. He will be able to answer better than me.
No Regrets
440
493
970
Midwest USA
Wow, this is a fantastic looking table! Anybody here own this table? Tell us what it sounds like….how does it compare to other tables you've had….how is the speed stability? etc, etc.
