12BH7/12BH7A Recommendations Please
JackD201
1,429
1,820
Manila, Philippines
Looking for strong, neutral sounding tubes for driver use. I don't need any added lushness. I'm actually looking for a bit more linearity and clarity. Both new production and NOS/NIB would be much appreciated. Currently using JJ ecc99s which are aging quickly.
TIA!
MylesBAstor
81
1,725
New York City
TIA!
You mean after 100 hrs?
JackD201
1,429
1,820
Manila, Philippines
About 2000. What does Nick use? I'll probably use some spares from my ML1.1 but I haven't looked at them yet so don't know what they are.
MylesBAstor
81
1,725
New York City
Not sure. Perhaps MadFloyd can answer as I think his unit uses 12BH7s.
mep
17
It's hard to go wrong with any NOS American 12BH7. RCAs are just dandy.
JackD201
1,429
1,820
Manila, Philippines
So am I. I usually roll only input tubes. In the case of the LL2 I couldn't honestly say I heard much difference (if any) swapping the driver tubes (6922/6dj8) while there were very obvious differences rolling the 12au7s. True to my mantra, I saved my money there and stayed stock. In this other preamp I'm using 802s with the stock JJ but as I said these are going south. What I'm pretty sure I'll get is a slight reduction in gain since BHs aren't exact drop in replacements for 99s. The designer says it will work though so I will experiment.
arnies
104
88
1,583
Austin, TX
TIA!
Hi Jack,
I just received my VTL Siegfried Series 2 amps from VTL and they use 12BH7 tubes as driver tubes (2 per mono block). VTL uses the Electro Harmonix 12BH7 tubes and for an input tube they use the JJ12AT7 tube. The JJ 12AT7 tube is awful sounding as I have been experimenting with several different NOS tubes that are far away better sounding. But, perhaps the EH 12BH7 might be worth a try for you.
Arnie
JackD201
1,429
1,820
Manila, Philippines
Hi Arnie,
Thanks! I'll give them a shot. As it turns out, my brother who has VTL Sig IIs has a stash of 12BH7s. I should have known he would except I didn't know the tube complement until today :D
Anyways, he sent me a pair of RCAs to start.
mep
17
Hi Arnie,
You can't go wrong with those Jack.
arnies
104
88
1,583
Austin, TX
Hi Arnie,
Hi Jack,
You're welcome.
If you get a chance, can you ask your brother what 12BH7 tubes he uses in the Siegfried Series 2 - Thanks
Arnie
MylesBAstor
81
1,725
New York City
Hi Jack,
Arnie
What JJ tube sounds good? Any resemblance between the JJ/Tesla 12AX7 and a real Tesla 12AX7 is purely coincidental. Plus the Q/C is awful.
I gave my friend a pair of $35 Mullard CV4024 tubes for his VTL 400s and they sounded very good in his system.
Hi Jack,
Arnie
Arnie
IMO the only 12AT7 to find is Telefunken NOS ECC 801S
arnies
104
88
1,583
Austin, TX
Hi Myles.
I agree that the few JJ tubes that I have heard sound terrible. I have been listening to a Valvo 6201 Gold Pin replacing the JJ 12At7. This is a major step up in sonics.
Arnie
mep
17
Hi Steve,
Thanks for the input. I will take a look at those as well.
Arnie
Tele ECC81 tubes are also very nice and the price isn't as snooty as the ECC801S.
JackD201
1,429
1,820
Manila, Philippines
Hi Jack,
You're welcome.
Arnie
Hi Arnie,
He uses RCA.
DavidDownham
1
Whilst this thread was started by 'arnies' to evaluate 12BH7 tubes, may I take this slightly more off thread? (in view of the fact that nothing has been added since 2013 I can't believe this should prove a problem?)
Recent posts have discussed the possible upgrade of tubes for VTL Amps-not just in respect of the 12BH7 tube.
Now, interestingly I bought a VTL Amp just over a year ago. At the time I contacted VTL ( and the UK Distributor -Kog Audio) with regard to possible tube upgrades.Both were dismissive of the idea !!
I didn't take it any further at the time but I'm now having to consider replacement tubes. ( which is how I can to this thread)
So,you lads who have VTL amps, what's the recommendation ??
That is, for the 12BH7,12AT7 and the KT88?
DaveC
3,899
2,143
495
Any 12BH7 will be good, better than the JJ ecc99
See Steve's post above on at7s
On KT88 I'd go with Winged-C or Gold Lion reissues
