Steve has the Alexandria Series ll so would be good to know the answer in that case just the same.You would want to ask them specifically about the older Watt/Puppy. I can't speak to newer designs, although so far our stuff sounds fine on them.
(...) You have a good relationship with Wilson folks. Do you want to run this argument and ask them what they think? Clearly they either intended this to happen to or not. If they intended, then we need to know what range of amp impedance they assumed and no one should use their speakers with anything else if they expect accurate reproduction. I recall them always use your LAM amps at shows in the last couple of years I have heard them so perhaps there is something there.
The conclusion therefore would be that such a speaker would not sound correct with vast majority of amps that have very small output impedance. In the specific, your Wilson speakers would never sound right with a solid state amp.
Why do you assume global negative feedback is the only way to achieve a low output impedance? That seems very prejudicial, let alone false.It depends on whether your top priority is sound quality or virtually carefree system matching. If the latter, then solid state amps with large amounts of global negative feedback offer all you could ever ask for.
Bold 1: Perhaps you should, because so far all you've done is provide evidence that given enough care in matching amp and speakers, one of OTL's classic weaknesses might be overcome. And by smoother, I assume you mean more linear?
Bold 2: This "real" reason for the use of OTL amps, I'm sure you've noticed, is almost universally accepted by the devotees of OTL amps, but it doesn't get any traction outside the club. While you're making your case, if you really have an interest in doing that, you may want to show some statistical evidence of which distortions matter to human hearing, at what levels, and some examples of OTL amps audibly reducing the distortions that do (once you've established that), relative to SS amps of equal quality. Otherwise, you're just another OTL fan praising that thing you like the sound of. This is an audiophile board; we don't need to be convinced that some people enjoy THD. I do need to be convinced that the presence of a bunch of it audibly reduces distortions that have been demonstrated to be more audible and objectionable to more listeners, not just anecdotally reported as such by fans. Don't get me wrong, this is a OTL discussion with a chart in it; I appreciate the progress, but we're still barely lifted above he said/he said.
I don't really have any issue with Ralph's terminology, but I think it is useful to know when "engineering" terminology is really not - not universally defined, understood or used -- but is, instead, the invention of the author and adds no credibility, substance, or even a point of reference beyond the author's position.
Tim
You mean voltage paradigm, no? Are not most amps voltage paradigm? Certainly true for SS amps. I'd say also the case for tube amps. First, we have to use the correct criteria. This "same power for different impedance" is being misinterpreted as a criterion for power paradigm. This has a) nothing to do with the max output (i.e. 10% or 1% THD) power, and b) it has nothing to do with a nice tube amp such as McIntosh that offers the same total power into 2, 4, 8 ohms, as that only happens when the speaker of that impedance is connected to those three different sets of output transformer taps.On the other hand, there are still many open questions, the most important of which for me are:
a) No one has yet come forward to name *current-day* SS amplifiers or other tube amplifiers that are not following the power paradigm;
Based on my previous paragraph, I would assert that the McIntosh amps are voltage paradigm, since they behave essentially the same as far as the amp/speaker relationship is concerned as SS voltage paradigm amps. Atma-Sphere stated a power paradigm amp exhibits "moderate output impedance (1-20 ohms is typical)". An easy way to make an amp with a 10 ohm output impedance is to add a 10 ohm resistor in series with the speaker. Or pick whatever value makes the speaker sound best.b) No one has directly discussed amplifier output impedance and how that fits into either the so-called voltage paradigm or the the power paradigm; more importantly, what is it that makes a design follow one paradigm vs/ the other - we would like to see formulas that also involve the load itself. We don't even know what the true output impedance characteristics of Atmasphere's OTLs are.
When you design a set of speakers for these power paradigm amps are you aiming for as flat an impedance as possible, or at least trying to minimize nasty impedance peaks?
Or you can use a McIntosh tube/transformer amp (or the like) which has an output impedance of <0.1 ohms.How about a speaker that does not work so well with an amplifier with no feedback? One example I like to use is the B&W 802. This speaker is nominally 8 ohms in the mids and highs but it 4 ohms in the bass where the load is two 8 ohm woofers in parallel. The efficiency of the drivers is such that the woofers are 3 db less efficient than the midrange and tweeter. But there are two in parallel so we know that the sensitivity of the woofer array is increased by 3db. If your amplifier can double power from 8 to 4 ohms it will work fine with this speaker. OTOH if the amplifier does not double power the result will be a 3db 'shelf' of reduced output operating in the woofer region. IOW the amp will sound a little weak in the bass, even though it may have good extension. You can improve this by adding feedback to the tube amp but you will also pay the price of the amp getting brighter and less musical.
This constant hammering on feedback is getting a little tiresome. There are other ways to achieve low output impedance without global negative feedback. Dismissing all feedback as harmful is baseless.So here is where I see the Power Paradigm as better: if the speaker requires the amp to have feedback in order to work, it inherently will be violating one of the most fundamental rules of human hearing, that of being how we perceive sound pressure.
Wha I said has nothing to do with Floyd Toole. I am repeating the argument being made by people posting here. If they are not saying that they produce more accurate reproduction then I don't know what they are saying.Amir,
You really have a good sense of humor! I do not think that Wilson folks have the same definition of sound accuracy as F. Toole.
Then your practical experience is disputing the case being made here for constant power, etc. That argument falls apart if amps regardless of output impedance sound great.not sure that I agree with this statement. Ask Christian how his X2 series ll's sound with his SS amps. Before I went all tubes the SS amps driving my speakers were Krell 750Mcx and they sounded darn good
Bold 1) I'm not engineer enough to come up with mathematical proofs (of my claim that "an OTL amp + optimized speaker will, for a given box size and efficiency, give you deeper and smoother bass extension than you'd get from the same size box and efficiency optimized for a solid state amp"), so I'd have to resort to modelling examples. And I'd probably be accused of picking examples that prove my point. So how about I give you a chance to participate here, no one is going to accuse you of intentionally picking an example that supports my position.
Refer back to the example system I described in post #41 (Faital 12FH520, 6 cubic feet, 35 Hz tuning, 4 ohm amplifier output impedance). That woofer has a calculated efficiency (based on T/S parameters) of 96.2 dB/1 watt. Pick any woofer you want that has approximately the same efficiency, adjust the Vas until the calculated efficiency actually is the same (so that we're comparing apples to apples) and model it in a 6 cubic foot vented box tuned however you want, adjusting the input voltage so that both speakers are seeing the same wattage based on their voice coil resistance, 5.1 ohms in the case of the Faital. See if you can get BOTH a lower F3 AND a smoother response curve using an amp with negligible output impedance.
This should be a total piece of cake for you, because the example in post #41 is not optimized. I just picked that woofer, box size, tuning frequency and output impedance off the top of my head without doing any modelling (though I did subsequently model it to see if it would make my point, but did not optimize it further).
Once you've proven me wrong there, we'll move on to Bold 2.
I am taking what you say at face value. If so, then there has to be the case that solid state amps with the same speakers produce worse fidelity and speaker manufacturer agrees with that. It can't be that both amps as I mentioned to Steve sound great.We already know that one works... The MA-2 works very nicely with the Alexandria- we've even built them custom with matching finish. Whether that is by design or not is unknown (although the national sales manager for Wilson had a set of MA-1s and later had a set of MA-2s), but so far I have yet to hear of an incompatability with Wilson and our amps.
I hope you appreciate that we need objective independent data on such things. Anecdotal information from parties with an interest in the outcome don't travel far .We have a customer that used our little S-30 very successfully on his later Watt/Puppy setup, eventually he graduated to a set of M-60s. As Wilson stated, you can use them with an SET if its enough power; that is what our customer was using before he got our stuff. At any rate I have been able to recommend Wilson to our customers for the last 20 years with no worries.
The B&W has some certain design flaws. So I would buy that if you messed around with how you drove it, maybe subjectively it would sound better. A better solution would be to get a speaker that doesn't have such serious directivity problems (B&W is speaker B):How about a speaker that does not work so well with an amplifier with no feedback? One example I like to use is the B&W 802. This speaker is nominally 8 ohms in the mids and highs but it 4 ohms in the bass where the load is two 8 ohm woofers in parallel. The efficiency of the drivers is such that the woofers are 3 db less efficient than the midrange and tweeter. But there are two in parallel so we know that the sensitivity of the woofer array is increased by 3db. If your amplifier can double power from 8 to 4 ohms it will work fine with this speaker. OTOH if the amplifier does not double power the result will be a 3db 'shelf' of reduced output operating in the woofer region. IOW the amp will sound a little weak in the bass, even though it may have good extension. You can improve this by adding feedback to the tube amp but you will also pay the price of the amp getting brighter and less musical.
The problem is that we can't demonstrate these issues in listening tests. Solid State amps with negative feedback routinely sound like real music.So here is where I see the Power Paradigm as better: if the speaker requires the amp to have feedback in order to work, it inherently will be violating one of the most fundamental rules of human hearing, that of being how we perceive sound pressure. In addition a tonal coloration (brightness) is introduced. Thus such a speaker might sound like a good stereo, but it has no chance of sounding like real music.
mep, your Appeal to Authority here is a classic Logical Fallacy. Just because Bob didn't know of the amp in bold does not mean it does not exist. For that matter I don't know of one either, in strict terms, but if we speak in terms of decibels than I can name quite a few. Further, the constant current amps he mentions of course are not constant power. The comment actually points to his ignorance on the topic. His closing argument is also a Strawman- I never made the stereotype he suggests.
One question for mep, do you believe that you have more experience and knowledge of amp design than Ralph Karsten? Because, IF you don't, what is the point of this thread?
Do you have any papers you could reference with regards to McIntosh being leaders in the voltage paradigm? Since both McIntosh tube amps and all but their cheapest SS amps use output transformers, that puts them in the “power paradigm” camp and not the “voltage paradigm” camp. And it would only follow that if McIntosh amps were designed following the rules of the “power paradigm” that their speakers would be designed the same way.
You are mistaken- output transformers have nothing to do with this one way or the other. It is more about global loop feedback.
Let's cool off on personal comments guys. There is plenty to discuss on technical front that such commentary is not needed.
Also, there's the false assumption that trouble-free system matching and best sound quality are somehow mutually exclusive.
