with the resugence in vinyl im hoping there will be other ultrasonic type LP cleaning machines around the corner to give us yet more and better options
Here you go, Rob:
http://klaudio.com/
I have one, and it's amazing...
I have one in house
IME, the audio desk and this machine requires another accessory...human elbow grease To Pre scrub new or any record being cleaned for the first time with enzymatic cleaner. Finger prints, pressing release grime wil not be removed by ultrasonic alone.
my thought exactly. in fact i dont want the drying function in the same machine as id dry the last disc while cleaning another and it makes the machine unecessarily complex and more stuff to break. correct me if I’m wrong but the autodesk and apparently the KLaudio don’t allow for longer than a 5 min wash cycle. the throess paper mirrors what others on the DIY boards have said, you need to elevate the temperature of the cleaning solution (thoresse example 113f) along with longer dwell time up to 30 min.
but the solution is still at room temperature right? it doesnt clean thoroughly w/o temperature controls according to those that should know.
Well ? You have tried both I assume....
. I am confident the records are as clean as they can get with my current workflow. There is no substitute for a good cleaning brush used with appropriate cleaning solutions and elbow grease.
Can you explain your current workflow for cleaning records in a bit more detail?
Does anyone use an ultrasonic cleaner in conjunction with a wet cleaner like a Loricraft. I've always wondered if they would work synergistically. Getting the playing surface as clean as possible seems to be critical for best vinyl performance.
me.
i have the Loricraft PRC4 Deluxe and the Audio Desk. it allows for both quick clean, and deep chemical attack on tougher pressings.
Hi Dre,
First I lay down two micro towels on the table. I scrub the record on them using a disc doctor brush with AI Enzymatic wash. I wipe each side off dry with another micro towel. I then finish the record in my Audio Deske RCM. That's it.
Ooops!
So have you compared using the machines in series vs alone? Does the order of use make a difference?? Sounds like an interesting experiment...hmmm
