Thanks. It would be interesting to see the rest of your WASP worksheet numbers.
My A1 is 44".
I'm still trying to figure out if the Alexias will work in my 12' x 18' room, before I fly over to Oahu to hear them.
How were these graphs measured? Nearfield, 1m, 2m, etc.?
alexandre
AGGGHHHH! What does it matter? He could put the microphone in the upper right hand corner of the room or for that matter in another room altogether, and the speakers will still sound the same! I don't understand what you are looking for? No one I know has measured speakers and we all have great sounding systems.
Wendell
OK I'm with ya then. How are you going to eliminate what appears to me to be a 20db plus freq response variation? If I get you right, that is what you are saying, that you are looking to automagically turn your freq response into a +/- 3db freq response. And I will try to remember that you have a different goal in listening to speakers (and music also I suppose) than myself and just about everyone else on this forum.
How are you going to correct it? I guess the only way is EQ, is that in your mystery bag of tricks? You mentioned previously you some EQ capability. I do hear the DSpeaker EQ can be the cats meow, but I have not heard it personally.
Wendell
This is probably the hardest part... that last 2-3%. I know getting it perfecially flat is not going to happen, but at least get it as linear as possible without any major dips/peaks. I do have some flexibility in my listening position and I've already decided to put 2 subs in here and maybe a good EQ system. Now I just have to find them!
I know the subs can take care of the dip at 62Hz and maybe smooth out the response a little more up to 200Hz. We'll see. My only other concern is the 1300Hz null which I might be able to fix by moving my listening position.
Changing the tweeter resistors may help with 1300Hz null.
Hi Bruce, Don't get your undies in a bunch. Hey, I am on your side, I think the Wilson is a good speaker, as well as your previous speakers the Evolution Acoustics. If I could afford either set they would be on my wish list.
You say the Alexias sound great, I am happy for you, because you did not like the MM3s. Now you say the Alexia sound the best you ever heard (again congratulations) but you are looking for accuracy.
Wendell
Why is it that *everyone* seems to have a room dip at around 60 Hz to 65 Hz? I have now seen that same dip numerous times. Everybody has different rooms with different nodes and different speakers placed differently within the room. I'm surprised that in spite of those differences, there is some commonality with the dip centered between 60 Hz to 65 Hz in multiple rooms.
DSpeaker is the cat's meow BUT only works below 300 Hz
Does the tweeter go down that far? Do you know the x-over point?
