Ah but your DAC has a built in filter so the downstream stuff is far less critical than if the filter weren't present.
What to look for is an input stage which is very linear down at lower levels and also linear up to high frequencies, beyond those in the audio band. Valves would normally qualify at the top, discrete JFETs would come next, discrete bipolars after that and integrated circuits which don't use long-tailed pairs. The bottom of the pile would be normal opamps with low-noise, long-tailed pair input stages.
Alternatively, sufficient passive filtering prior to any active stages might work well too.
<edit> I've added a technical paper which gives (to me at any rate) a very satisfying technical reason for why normal opamps aren't very linear up to high frequencies.
