-- Ralph, what percentage of your music listening is consecrated to analog, and digital?
Happy New Year! :b
Bob
Happy New Year! :b
Bob
At home its all analog these days. At work its about 50/50.-- Ralph, what percentage of your music listening is consecrated to analog, and digital?
Happy New Year! :b
Bob
With the right speakers, cables, tube pre and CDP, I find analog redundant. And that surface noise drives me nuts, IMHO.
So it takes the "right speakers, cables, tube pre and CDP" to make analog redundant?
What happens if you have the wrong speakers, cables, tube pre, and CDP?
Happy New Year y'all!
This might come as a suprise, but the choice of phono preamp can have a huge effect on surface noise! I am not used to hearing much in the way of surface noise anymore, once I sorted out what the big varibles were in the phono section. The difference can be pretty dramatic.
To digital people who have an intense dislike for analog, even not "hearing much" would be way too much for them to take. We have one guy on this forum that says he can't and won't tolerate a single pop or click.
There is definately a preference here! In my case I'll take the pop or click if it means that otherwise the playback is musically endowed and lacking coloration. I've yet to hear that in a digital system at any price; while some of them a fairly musical, none are uncolored - they all sound bright to me. I've mentioned before that the best (IMO...) out there right now is the Stahltek which is a $72,000 system. I say its the best as it is the most musical by far and the least colored by far, but compared to the LP playback of the same track the improvement of the LP is instantly apparent. In the words of the designer, "Digital has so far to go...". He's right! But I think his ready admission of that, his ability to simply deal with 'What Is', is why his gear works so well.
This is all very confusing. Just a post north of this one you told us "the choice of phono preamp can have a huge effect on surface noise." I think I do understand this. Let's bypass the hyperbole of "huge." All surface noise, of any size, is physical. It is the result of flaws in or on the surface of the disc (thus the name). The phono preamp receives that signal with the noise intact. If it has any effect on that surface noise, it can only be by making it louder by raising the volume of the frequencies of the noise, or making it softer by lower the volume of the frequencies of the noise. Phono preamps equalize and raise signal level that is given them at varying levels of purity and accuracy. Period. They have no noise reduction ability outside of those simple parameters. And what do we call it when specific frequencies are raised or lowered? Coloration. And yet you believe, at the same time that a phono preamp is lowering the volume of the frequencies of very audible surface noise, it is "lacking coloration." That's interesting.
Tim
Tim,
It was confusing for you when I addressed this same issue some time ago, unsuccessfully trying to explain you that some hardware manages to separate the surface noise to another plane from that of the music, in a way it seems it does not contaminate the recording and our enjoyment of it. Mark Lavigne and Gary also addressed it in their descriptions of great LP playback. And yes, the effect is huge. I hope Ralph manages to explain it better than me.
BTW, you should listen to Ralph OTLs. After ten seconds you will understand that he is not the kind of person who enjoys attenuated treble frequencies . His amplifiers are flat to 100KHz within 1/2 dB and are known for its extension - I quote an old Paul Bolin review in TAS: In the treble, the MA-1 is almost a revelation. The top octave seems to extend to infinity, and does so with a combination of delicacy, airiness, and refinement that set it in a class by itself.
I remain confused, not because your explanation evades me, micro, but because you have offered none. You merely say that it is, and so I assume that you have no explanation. There are no planes in a preamplifier; no dimensions beyond the design and engineering of the device, to which noise can be banished, leaving the music untouched. Not even in a $72,000 phono stage. Regardless of the mythic proportions of such a price, such a preamplifier, like all preamplifiers, is just a collection of electrical parts in a circuit. No planes. No myths. It doesn't seem; it either is or is not. Any ability it might have to reduce, much less remove, hugely, the record's surface noise from the signal will be revealed in the amplitude of the frequency of the noise in question, and it will, of course, have the same impact on the amplitude of everything else in that frequency range. This is not religion. It is mechanical. It is electrical. And if it is real, it is explicable in mechanical and electrical terms.
Tim
