Can I use 15amp 125V IEC for 240V components?
jtein
97
Malaysia
Hi folks, I'm from Malaysia and the voltage here is 240V. We use UK sockets with 13amp plugs. But many audiophiles over here prefer to terminate their power cords with US wall plugs and IECs. I notice that the IECs are usually 15amp 125V. Would using them have any adverse effect on the components that are rated 240V?
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Shouldn't do, the difference in voltage is neither here nor there. There may be a slight benefit because the 125V connectors have to nominally handle twice the current in a comparable cord, so should be a bit better made; somewhat more meaty metal to handle the higher current ...
Frank
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
The equipment should be fine. The cord though, may be less safe as its insulator is rated for half the voltage.
jtein
97
Malaysia
Would that imply that all US made power cords may be less safe for use in countries where the voltage is 240V?
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Only if it is marked at 120. For example, the power supply on laptop power supplies is designed to work worldwide so its cord is also rated for the higher voltage.
The danger here is very small and the thing that comes to mind is leakage to the surface. Run your equipment and touch the wire to see if you feel electricity leaking to outside of it. I doubt that you will feel anything. But if you do, it is not a good sign. The other issue which you must avoid is total power through the cable. At 240 volt and the same amps, you can draw twice as much power through the same cable. That causes double the losses in the cable, potentially compromising its insulation. Worse yet, the fuse/breaker in the house will not protect it against shorts and risk of fire. I suspect your gear doesn't pull twice as much power so this is not an issue in this situation.
Mind you, many times the cable is also good for 240 but manufacturer saw no reason to test it at higher specs. This is why I said risks are very low.
BTW, IEC spec goes up to 250 volts. Why not use a cable rated at higher voltage to start? Here is a random one that came up in search: http://www.costcentral.com/proddetail/Eaton_Corporation_EATON_ePDU/0100028/Y71595/
Speedskater
941
15
368
Cleveland Ohio
I think that you will find that quality US market cables are all rated at 300 Volts if not 600 Volts. (This type of voltage rating is very conservative)
If the internal resistance of a length of wire remains the same and the current flow remains the same, then the internal power lose of the wire remains the same regardless of the supply voltage.
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Sorry, Amir, that doesn't make sense: the amps will draw the same power through the cable irrespective of the voltage, all other things being equal. What will change is the current drawn, and for 240V the current will actually halve, not double; halving the resistive losses in the copper resistance of the cable. There should be no risk of over heating, or fires, whatsoever.
The only possible danger, extremely slight, is not the nominal voltage, but what happens when a nasty voltage spike, say from a lightning strike nearby, comes down the cable. This could be, say, peaking at 2,400V: insulation always has a hefty safety margin built in so it's not a problem, but if some of the construction of the cord is a bit dicky there is a slight chance of a flashover, spark, occurring.
Frank
Keith_W
1,024
95
970
Melbourne, Australia
www.whatsbestforum.com
Before you use them make sure you check with your insurance if this is OK. If your house burns down in an electrical fire, your use of non-standard plugs might be an excuse for them to deny your claim even if these plugs had nothing to do with the fire. Insurance companies are bastards!
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,010
1,320
Hello, jtein. How many amps are you planning on running through said cord?
jtein
97
Malaysia
Whoa...no wonder I felt some serious electric current when I wanted to disconnect my interconnects from my preamp! That must be leakage to the surface of the preamp?? Anyway, those were my old power cords with 15A 125V plugs and IECs. Currently I'm using JPS Labs Kaptovator terminated with 10A 250V IECs, but the male plugs are still 15A 125V. Is that ok?
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
You didn't follow what I said Frank. If the equipment power consumption stays the same in both cases, then what you say is true and I ended the paragraph the same way. But there is no guarantee that is the case. If I take a 240 volt 15 amp hot water heater and put a 120 volt IEC connector/cable on it, it will be subjected to twice the power it would normally be subjected to. The current is staying the same but voltage doubled. If the equipment is rated at 240 volt, there is no assurance that it only consumes have the max power.
jtein
97
Malaysia
Hi treitz, currently I'm using Kaptovator power cords terminated with 10A 250V IECs and 15A 125V male plugs. I just discovered this. Hence my original question.
Also, I've just upgraded my AC conditioner so I need to upgrade the power cord from the wall to the conditioner. My dealer suggested that I should change the standard UK wall socket to a US one because more current can be delivered. I've calculated that it's usually cheaper to purchase stuff from the Cable Co. than from local dealers here, even after factoring in shipping costs etc. That's another reason for my original post.
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
That sounds to me like static buildup, a totally different thing. But sensing static anywhere typically will mean a loss of sound quality, especially with digital; so it's still worth finding out what's causing that ...
If anytime you "feel" leakage from mains voltage this will be a constant sensation, whereas static will give you a short, sharp shock, that almost instantly disappears. Otherwise, if you have mains leakage, this is mighty, mighty dangerous -- something to be sorted by an electrician, or reputable electrical repairs company.
Frank
jtein
97
Malaysia
Frank
Frank, I doubt it was static charge as it was a constant sensation. But I don't have that problem now that I'm using Kaptovator cords terminated with 10A 250v IECs.
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Amir, the key point is the current drawn: that determines the losses in the cable, because of the inherent resistance of the cable and connectors; the voltage doesn't come into that. And a cord designed for a lower voltage, say 120V, will typically have lower resistance because the devices connected need to draw twice the current for the same power consumption.
Frank
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Well, there's something weird going on! I'd be going to some effort to check this out, maybe it has something to do with how power is distributed where you are, and how earthing is done.
The connectors you're using are rated at least at 10A, and that's plenty; unless you're running a fleet of overr the top class A amps. The big advantage of higher amperage connectors, and US wall socket is that the residual resistance should be less: this minimises voltage loss when a current spike is required, and should help your power amp to perform a little bit better.
Frank
jtein
97
Malaysia
Frank
You mean that the current leakage has nothing to do with what amperage/voltage of the IECs and wall plugs?
JackD201
1,429
1,820
Manila, Philippines
In the Philippines we use 15A specifically NEMA 5-15 like those in the US. We run 230V. I've never seen any problems with the connectors/couplers (C13/C14 on the equipment end). There might be potential problems with the cables but not the couplers, plugs or receptacles. The big mass market producers of these over spec precisely so you can use them from 100V to 240V. It's saves them money in the long run just having one production line.
Yes, insurance companies are bastards.
Onepoint5
47
13
913
If you have 240V from the wall, you need to rate, connectors, cable to your equipment at least the same or at a higher voltage specification. The materials that make up the cables and connectors are designed to work (forever in mind) at the voltage you apply to them. As an analogy, if you put 100lb pressure in your tyre when it's only designed for 50lb, it will burst. The same applies to insualtion materials, over time, the chemicals that make up the insualtion break down (under pressure), yes they are applied with voltage too, it's their properties that keep the dangerous bits away from our hands. This breakdown appears as a crack or a britle appearance, the worst is that you touch the connector and it falls apart in your hand and you touch 240V. Clearances between live and earth parts are very different between 240 and 120V connectors and sockets, the higher voltage, the greater the creepage distance needs to be,
For connectors, make sure that the voltage rating is stamped on the connector and at least have a CE, VDE, UL, CSA or other authority verifying the cable or connector meet standards,
Lowering the power demand by half and still having double voltage, sorry that's not right.
