Do you know of cheap tweaks that can sway an honest objectivist?
caesar
775
1,698
Ayre Irrational but Efficacious CD for $20. No one seems to know why it works, but boy, does it work?
Do you guys know of any other high value / dollar tweaks?
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
Cleaning all your jacks, your speaker wire terminals, your interconnect's ends, your banana plugs (or spade lugs), your AC power cords, your inside wall electric receptacles, your junction breaker box, and all that Jazz ... :b
MylesBAstor
81
1,725
New York City
+1
MylesBAstor
81
1,725
New York City
Replacing your worn AC receptacles. Drops the system's noise floor and improves dynamics and resolution.
Making sure of the correct AC line polarity for your AC plugs.
Replacing the throwaway AC cord on most digital gear. For whatever the reason, AC cords make the most difference on digital gear. Even a correctly chosen, modestly priced cord provides a significant improvement.
Though not necessarily the cheapest ($360/4 panels to treat a room), the Cathedral sound panels really help tame room acoustics. Be careful though: a few inches can make a sizable difference in their performance. http://www.ultrasystem.com/usfeaturedPanelsdescript.html
Don't put the turntable on top of the speaker. ;)
NorthStar
24,305
1,323
435
Oh, and regulalarly. Say every six months or so (at least every year).
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,010
1,320
Adding weight to stands and placing even more weight on top of speakers, the coupling or decoupling of speakers, isolation of gear and the cheapest of all? Plants to diffuse. Along with what has already been mentioned.
Perhaps the cheapest of all? Moving your rig to a different wall or room within the house.
MylesBAstor
81
1,725
New York City
rockitman
7,097
414
1,210
Northern NY
$360 for the Cathedral Sound panels ;)
what frequency range are they tuned for ? I suppose that is a good inexpensive way to go but I'm not sure you will come close to a flat frequency response room with them. Something like real traps where they are frequency tuned for bass, first reflection mid/hi and all frequency traps behind the listener makes for an optimal sounding room. They are much more expensive, but you get what you pay for. I spent close to $5k to properly treat a 16 x 16 space.
MylesBAstor
81
1,725
New York City
The link is above :)
While they may not be ultimate, for under $400 they do they job and bring you a large part of the way to the final destination. Rich was over one day and couldn't believe how much of a difference they made in the sound of the room!
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Where does one start? There are so many things that can be done, all which will improve the sound, but will often just make the more "obnoxious" recordings sound worst if just done in isolation. The greatest tweak of all is to do everything in one hit, that you know influences the sound in the direction of revealing more detail in the recording, and see where that gets you.
Dump all tweaks that make "difficult" recordings "nicer" to listen to because you lose a bit of everything; you're going the wrong way there ...
Frank
NorthStar
24,305
1,323
435
Drink less. ...Not only it's cheap, but you save money too; for buying more good music. :b
...And of course, you hear with more clarity and better concentration.
Syntax
259
307
970
At The Dark Side
True. But drinking Alcohol makes the most components sound better. PRaT is the key word.
Much better. And you can hear details which were not there before.
I think, downing a bottle of wine is in general the most popular tweak.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
Speaker positioning. An hour or three can do wonders for many systems.
+1 - definitely the best value for money tweak there is out there.
Another is the positioning and support for the turntable - a $20 Ikea butcher's block, a few hockey pucks and/or felt pads.
Syntax
259
307
970
At The Dark Side
fas42
Addicted To Best
Jan 8, 2011
3,973
3
NSW Australia
Remarkably simple: once gear is fully warmed up, conditioned, and you feel the sound could be a touch, or more, better, switch off everything, especially all digital gear. Leave for 30 secs, or however long to let all the smoothing caps discharge to a near zero level. Then switch on again, immediately start replay, and pay very close attention to how the quality changes, or doesn't change, over the first 5 or 10 minutes or so.
Could possibly tell you something ...
EDIT: I'm gung-ho about power supplies. My last self-designed effort had very large reserves of effective charge; I could pull the plug on the amp during playback at normal volume levels and still get clean sound for another minute to 2 minutes, depending on the source material, until the voltage dropped too far.
Frank
