Waversa Bridge - digital processor and on-the-fly digital format converter! Likely an industry first!
ketcham
159
98
135
Introducing an industry FIRST. The most advanced Waversa digital-digital processor, designed and manufactured in-house, improves the digital stream and converts any digital standard to any other digital standard featuring complete versatility.
The WBRIDGE has three different configurations:
WBRIDGE Basic
- LAN Ethernet only featuring impressive Ethernet switch technology and digital-digital processing in the industry. $4000.
WBRIDGE Standard - Additional features of on-the-fly conversion of digital signal standards. $5500.
WBRIDGE Multi - yet to be released featuring customizable additional 3-way digital crossover. $7000.
MAIN FEATURES
• Complete noise protected hardware construction.
• All audio interface with cross conversion.
• ROON
• DLNA
• AirPlay
• Waversa Smart Battery Charger System
• 4x Battery operated Audio Grade Ethernet ports
. • Clock input/output • 4x 18650 Lithium Battery Slot
• Built-in Linear Power Supply
EXCLUSIVE TECHNOLOGIES
• WNDR - Waversa Network Direct Rendering
• WAP – Waversa System Processor (Basic: 5, Standard: 10 (5+5))
• WAP/X - Waversa System Processor Extension
• Dynamic Range Support Levels 1 - 5
PHYSICAL CHARACTERISTICS
• Chassis: Aluminium
• Colour: Silver
BASIC – 4 x Audio Grade Ethernet ports (with Native DSD)
STANDARD – As BASIC plus Digital Coaxial input/output, USB-B input USB-A output, Toslink input/output, AES/EBU and HDMI input/output (up to 4K pass through, ARC)
MULTI -- As Std plus AES/EBU (1 x Input, 2 x Output), USB-B Input, USB-A output, 3-way active crossover • I/O: Micro SD (Updates only)
• Dimension: 300 x 250 x 45 mm • Weight: 4.0 kg / - 8.8 lbs. • Power supply: 90~120 VAC/180~240 VAC@50~60Hz S
SUPPORTED AUDIO/VIDEO FORMATS
•COAX: up to 192KHz
•USB/NET: PCM 32 Bit 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384 kHz : DSD64, DSD128, DSD256
•ROON: FLAC, WAV, DSF, DFF, AIFF, ALAC, AAC, MQA
•UPnP/DLNA Renderer: WAV, AIFF, OGG, FLAC up to 24 bits / 192 kHz
SPECIFICATIONS
•AM3358 with TI OMAP 1GHz ARM Cortex A8
•OCXO Clock (Upgradable through external sync clock)
•Built-in Linear Power Supply
Reactions: Addicted to hifi
Addicted to hifi
4,615
1,984
265
50
Australia
WBRIDGE Basic
MAIN FEATURES
• ROON
• DLNA
• AirPlay
• Colour: Silver
•COAX: up to 192KHz
SPECIFICATIONS
Beautiful.looks very smart.
joeling
118
20
148
Can this be used as a Roon end point ?
ketcham
159
98
135
Yes. Like the router, both can be used as a roon endpoint.
Reactions: joeling
