I have a Curious USB cable, it is about 6 inches long. I just tried a 1M Pangea and to my surprise it sounded better! Is it because of the longer length or the cable itself? I know the Pangea usb is considered an el cheap- o cable, can someone recommend something better?
Thanks,
ozzy FC
I too was keen to check out an FTA Finope cable but that contravenes their business model. I’m quite happy with my Sablon Audio Evo cable and have ended my USB search. It’s price point roughly the same as FTA. Each company insists their cable is the best. Go figure! I think both FTA and Sablon SHOULD sound considerably better than a Curious cable as the cost is close to triple. I cannot speak with MUON as I’m unfamiliar with the line. And as I say, my hunt is over! Yeah!I was able to compare NA MUON USB with a Curious and Supra Excalibur cable in my speaker rig and a headphone system. It was clear from the first few moments of listening the MUON is in an entirely different league compared to either Curious or Supra. Everything simply sounds more real - tonality, density, clarity, dynamics, soundstage, etc. It is amazing how much digital noise this cable removes. I wanted to audition FTA Sinope and Sablon EVO but I was unsuccessful to work it out with either. The MUON is not cheap, but it is not crazy expensive. If you are looking for a no compromise USB cable you should include this in your list. Network Acoustics is also so easy to deal with. If you are looking for a killer cable in the affordable category you cannot make a mistake with the Supra Excalibur. This $120 cable performs at the level of the $350 Curious and in some systems some may actually prefer this.
Are you using the Muon USB with the filter or without it?I have a NA Muon USB (since two years) and have also a Sablon EVO USB (since a month).
I'm going back and forth, but the cable that consistently remains in my system is the Muon. In fact, I think I'll be selling the Sablon soon (even though a very good cable).
Just curious how do the two differ sonically? I always wanted to try the Sablon due all the positive comments but never got a chance and ended up w/ the MUON.I have a NA Muon USB (since two years) and have also a Sablon EVO USB (since a month).
in essence, the Muon is neutral, very clear, detailed and overall balanced. The Sablon is more bass heavy and somewhat colored.Just curious how do the two differ sonically? I always wanted to try the Sablon due all the positive comments but never got a chance and ended up w/ the MUON.
