Time Alignment For Subs
GaryProtein
2,542
31
385
NY
Digital Signal Processing
rbbert
3,820
239
1,000
Reno, NV
Assuming there is a phase control on your sub, play a test tone through the whole system at the Xover frequency and adjust for maximum volume, or alternatively wire the sub out-of-phase and repeat the procedure looking for the lowest volume (which many people may find easier to perceive)
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
That would give you phase alignment, not time alignment, no?
edorr
May 10, 2010
3,139
14
36
Smyrna, GA
Only if applied on all channels (which is usually not the case). Most folks insert a DSP box just to tame their subs, getting worse time alignment because they usually involve an A/D/A conversion, introducing delay for the subs.
mojave
251
Elkhorn, NE
If located the same distance as the mains and with a crossover around 80 Hz, a sealed sub typically needs about 2-5 ms of delay, ported subs 5+ ms depending on port length, and horn subs 12-15+ ms depending on horn length. I've never seen an instance when the sub needs less delay than the mains unless the sub is located a lot closer to the listener. Typically one can move the subs further from the listening position relative to the mains to time align if they don't have DSP.
Just for reference, the Behringer DCX2496 has a latency of 1 ms and the miniDSP has 1.5 ms. If you have passive subs, the newer DSP amps by Peavey, Crest, and Behringer have a latency of less than 1 ms and you can increase it with the delay setting. Active subs with DSP built in will already have some latency.
rbbert
3,820
239
1,000
Reno, NV
I'm under the impression that the phase control on sub amps effectively works as a delay, but I don't know that for sure...
jcmusic
400
6
925
Just Outside New Orleans, La.
Ok guys a little more info, this is my 2 channel system corner horns dual subs. The subs are about 2 feet closer to the LP than the mains the room is symetrical for the most part does this help?
Robh3606
1,477
468
1,155
Destiny
What are you trying to show us?? Do you have a step response for the system?? That's how you are going to see any timing issues. It looks like it is summing well the only I thing I see is your average spl level looks a bit lower below about 150hz.
Rob:)
dallasjustice
2,067
8
Dallas, Texas
There are some pretty clever ways mentioned that thread if you take a moment to digest it. I especially like John's method mentioned in post #11 of inverting polarity to get the largest dip and then reversing polarity. Of course, there's no perfect way to do it. I am no expert. But I have watched an expert do it properly. It really takes some ability with REW, the right gear and serious patience.
Nyal Mellor
590
4
330
SF Bay Area, CA, USA
Everyone integrating a sub into their system should read Barry Ober's page on subs (JL Audio Technical Support): http://soundoctor.com/whitepapers/subs.htm
The phase control on the sub just adds delay, and most of the time you actually need to delay the mains, not the subs.
There are some subs available that have internal DSP where you can delay the high pass output: Revel's new ones using the LFO software and Triad's. Or you can use a digital crossover such as a DEQX, Trinnov or pro audio unit. Or you can do all the crossover inside a computer and feed a multichannel DAC like an ExaSound.
The easiest way to integrate subs is just to play with delay until you get flattest response. It might take you some time to get there and you will never know if it is properly integrated (for example you may have just added a full cycle of delay to subs or mains and gotten a good SPL trace but the two are not in time alignment). The proper way to do it requires looking at the time domain. I look at impulse response and phase; it's not something that I have seen written down anywhere, and it requires a good understanding of acoustical measurements.
jcmusic
400
6
925
Thanks for the link and info this is the best info I have ever read on subs and intergration.
