Sutherland Engineering Timeline
ack
May 6, 2010
5,149
6
38
Boston, MA
#2
I set 33rpm speed by measuring a fixed frequency of 1kHz at the amplifier terminals, after assuring my Fluke's accuracy by playing a 1kHz tone with the CD player. This also accounts for stylus drag which is surprisingly significant. This is so accurate that if I then want to set 45rpm speed, I simply multiply the VPI SDS 33 rpm speed by 45/33.33 - the output frequency is then confirmed at 1.350 kHz
rockitman
6,868
1
38
Northern NY
#3
That sound's like a good option as I have a fluke multimeter...
MylesBAstor
I prefer the Digistrobo. Lot less headache, just as accurate and know the speed within 15 secs or so. You can even check the speed when playing.
rockitman
6,868
1
38
Northern NY
#5
Okay, that accounts for stylus drag too. I would think the multimeter would be most accurate as you get a specific reading rather than using your eye to see if the speed is stable...Nice option too. Thanks.
rockitman
6,868
1
38
Northern NY
#6
silly question, how do I hook the fluke up to the rca out's of my phono pre to measure frequency while playing a test tone record ? Do I need to fashion an rca jack for the preamp out end and bare wire at the other to hook up the fluke (+ and -) to one channel ?
rockitman
6,868
1
38
Northern NY
#7
edit...used and alligator clip for the black to connect to the shield of the rca jack and the red probe (+) to insert into the jack. Works like a charm. Thanks.
ack
May 6, 2010
5,149
6
38
Boston, MA
#8
Or just do what I do - plug it into the amplifier output, as I mentioned; unless you think your electronics cannot accurately reproduce a 1kHz tone, but God forbid in that case, that wouldn't be the high end...
rockitman
6,868
1
38
Northern NY
#9
post deleted as my information was incorrect. measuring frequency is not accurate to 1/1000th hz, rather it is accurate to 1 hz playing back a 1000 hz test tone
ack
May 6, 2010
5,149
6
38
Boston, MA
#10
worked great on my phono pre outs. I have to think that the multimeter is the most accurate method...to within 1/1000 of a Hz. Can't see how one can be that accurate looking at a strobe or the line on the wall as is the case with the Timeline. You saved me $400.00 ! Thanks.
Exactly - but only if you have a good multimeter like a Fluke. You are welcome.
ack
May 6, 2010
5,149
6
38
Boston, MA
#11
Here's another similar trick to set cartridge azimuth using your R2Rs VU meters or multimeter... play the same 1kHz CD tone and measure the output voltage at the pre's tape output; adjust internal preamp tape-out buffers till you get the same reading per channel (this assumes your CD player's/DAC's output is matched to very low tolerances between its channels, which is common, but you should measure that too; and that you can indeed adjust these buffers - on my Spectral preamp, I can).
Now that your preamp tape-out is calibrated, adjust azimuth using the multimeter, but I find it easier to use the VU, meters as follows: first adjust the input gain on the R2R so that both meters read the same 0dB reading with the same 1kHz CD tone; switch to the 1kHz tone on the LP and adjust azimuth till the VU meters read the same value.
