If I'm not mistaken Bruce runs native DSD most of the time. I don't know if he's keen on DSD-PCM conversion for his monitoring.
Also I am curious was not the room designed by your acoustic designer to work with the speakers on the end you originally had them? Won't moving the speakers to the other end destroy this balance?
Thanks,
Wendell
Here is the latest graph. The room has been turned around. I spent 5-6hr. this morning moving a 1/2 ton of speakers back and forth, moving my seating/microphone position and cheating a little.
+/- 5dB from 5Hz - 118Hz with 1/24 octive smoothing!
Hey there Bruce.... Nice frequency response! Can you tell me where in the room the speakers ended up to produce the graph shown above?
Thanks!
Could you please post a graph with the same parameters, IE: 2 to 1000hz, 45 to 105db scale and with the freq axis in logarithmic not linear mode (see how the spacing is different between freq ranges on todays post). This way we can directly compare the two responses to each other. Or perhaps you can post one graph with the original response and the new response in the same graph.
Hi Bruce, Well much better! Except for the "wonky" bit between 100 and 200hz which is worse, but overall much improved.
Is this with all of the contros set flat on the speakers? And can I assume now that you dont feel the need for equalizers?
Very cool. But do you feel that you needed the REW program to accomplish this?
Thanks,
Wendell
... along with my ears to make better decisions when mastering. There is still a way to go and I'm not against using multiple subs and EQ. I'd love to see +/-5dB from 5Hz - 20k
I'm really not looking for a particular sound. You have to remember, this is a working environment and not someplace where you can sit and chill out listening to music. If it sounds good, then fine. I just want it to sound accurate or true to the source that I'm playing. I want to make damn sure that when I add or subtract a dB here or there, it's because the music needed it and not my room/equipment.
There is still a way to go and I'm not against using multiple subs and EQ. I'd love to see +/-5dB from 5Hz - 20k (...)
About 36" from the side wall and 56" from the front wall
Hi Bruce, It seems that this thread has run its course, since there are no posts lately.
