SHM Platinum Discs , how much better ?
LL21
14,430
2,517
1,448
Here is some good information on the SHM/Platinum SHM.
Most, if not ALL of the standard Japanese SHM discs are the identical masterings to domestic releases here and the UK.
The so called Super High Material is purported to have sonic benefits, which are ultimately useless if you are ripping to a server.
The PLATINUM series is a different animal. These are made with the following method:
DSD transfer of flat master tape>176.4/2>Mastering>44.1 for CD.
I have found most of them to be much quieter and more dynamic that their standard "remastered" counterparts
although a bit more laid back and less exciting in some cases.
I have probably around 30-40 Platinum and around 100 SHM discs.
great to know. Thanks!
Drikus
1,390
223
985
Brussels
So a cd-player like mine, a Lindemann 825, who plays from memory buffering of the data doesn't have the sonic benefits from "The so called Super High Material" disc?
Andre Marc
3,970
7
San Diego
www.avrev.com
It may very well, you would have to compare the SHM and non SHM version of the title to really know, but I would not rule out the fact your player could benefit.
thedudeabides
2,187
699
1,200
Alto, NM
You should try both but I would think you would. My Cary has a buffer and it was certainly sensitive to better quality CD's.
Drikus
1,390
223
985
Brussels
But you said the SHM-CD's sonic benefits are ultimately useless if you are ripping to a server. So what's the difference between a cd-player who plays from memory buffering of the data and a PC/Mac cd/dvd-rom reading the same data but putting them on a hdd?
Andre Marc
3,970
7
San Diego
www.avrev.com
Totally different scenario. In you case, even with memory buffering the tracks are still being read by an optical drive. This is where the supposed benefits of SHM are.
Sever playback has so many variables it is beyond comprehension. Are you using a network? SSD drive? HDD drive? Audirvana? Jriver?
In my case, I use a NAS vis Ethernet and a number of streamers from Simaudio, SOtM, Byrston etc.
Once the file was ripped to my NAS, no laser touches it ever after.
As I said, in your case there many very well be benefits.
Drikus
1,390
223
985
Brussels
Just done a test with an SHM-CD ripped with XLD to a Macbook Pro SSD using Jriver and the same SHM-CD played back from my cd-player. Macbook Pro is connected to the dac of the cd-player. No sound difference...
Andre Marc
3,970
7
San Diego
www.avrev.com
That is actually very good news. :D
Those results can be interpreted a number of ways.
But to get back to the original question, you would have to have the NON SHM title of that CD on hand.
A good test are the Genesis releases, which are the identical digital mastering on the SHM and domestic releases.
Drikus
1,390
223
985
Brussels
I only have the Japanese 1970-75 SACD/DVD boxset from Genesis...
