Plasmatron AC regulator
#1
I'm not a fan in general of AC conditioners. I've used several, including transformers and they all seem to reduce dynamics or aggravate ground-loops.
One exception is the Plasmatron from VHAudio. Chris from VHAudio brought one to our exhibit room at RMAF and we gave it a try. I was immediately sold. For digital components, its simply the best AC tweak I have heard. Makes them sound more clear and at the same time, more analog. I think it regulates the AC voltage rather than filtering it or regenerating it. I run DAC and converters, everything digital from it. Highly recommended and the Thyratron tubes last a long time.
Steve N.
Empirical Audio
5,075
30
48
How does the Plasmatron work?
5,075
30
48
Thank you for posting that link. But I do not see anywhere on that website a description of what the Plasmatron is or what it does or how it does whatever it is supposed to do.
Do you?
Jan 20, 2013
336
1
18
London, UK
#5
#7
Meh, current and voltage providing the results? Its probably adding a hint of tube flavor.
Not that I can detect. Only goodness.
Steve N.
Empirical Audio
Folsom
2,557
2
38
Eastern WA
#8
Steve, if all the juice passes through something that gives it a pleasant harmonic pattern (including noise and tugging from various frequencies), why couldn't that be the result?
GMKF
320
3
18
Munich
#9
Interesting concept...
#10
It is certainly possible for someone else to make this mistake, but not me. I've been down the garden path many times and learned from it over the last 30 years. I now have one of the most resolving low-noise systems on the planet. I can easily hear the difference between an AIFF and a .wav file for instance. I can hear the difference in the same files with different sample-rates and different offsets. Any cable change makes a difference.
I have DC-coupled SET tube monoblocks BTW, totally modded by me and tubes rolled many times to get perfection. No "tubey" sound there. Tubes have a sonic signature usually because they are poor tubes, or the power subsystem in the component is poorly designed.
Steve N.
Empirical Audio
JackD201
[WBF Founding Member]
Apr 21, 2010
10,994
8
38
Manila, Philippines
#11
What effect does it have on analog Steve? I must admit that I have been very curious about this unit for at least a couple of years. Not to mention that they look really cool! I had a 2a3 amp built that used mercury rectifiers. To this day I regret selling it. I was made an offer I couldn't but should have refused.
#12
Have not tried it, but I'll bet its just as good or better than using on digital. Digital is the hardest to improve.
Steve N.
#14
Oct 1, 2010
910
Cleveland Ohio
#15
Now I remember, that 4 years ago, I posted this:
A 'thyratron' is just a Silicon Controlled Rectifier that light's up a pretty color. Remember those old light dimmer's that made noise in your hi-fi?
  • Founded in 2010 What's Best Forum invites intelligent and courteous people of all interests and backgrounds to describe and discuss the best of everything. From beginners to life-long hobbyists to industry professionals we enjoy learning about new things and meeting new people and participating in spirited debates.
