Pass Labs X600.8s
Audire
1,055
1,180
275
FL Panhandle
I’ve been very satisfied with our Pass X260.8s. However, after the demo of the EMM MTRX2s I determined I definitely need more power. Everything was better. But EMM never gave me the Class A power that they were delivering.… :(
The EMM isn’t within budget right now (saving the budget for the new room and equipment at which time I’ll be considering Gryphon as well), so I’m considering some Pass X600.8 monos to go with my present system. They will deliver more bass and are a good match with our Magico M3s. The 600s offer 100w of Class A into a 4 ohm speaker. Since my needles don’t move in my current set up (so it’s not in AB) the extra Class A power will be more than enough. And if not with 4 ohm speakers there’s 1200 w of power.
This said, is there another set of “monos“ you would suggest? They need to be SS, powerful. I’d like to spend no more the 17K + the trade in of the 260s.
Here’s a reminder of what I presently own:
Thanks in advance.
AMR / iFi audio
2,109
916
215
42
UK
ifi-audio.com
Thanks in advance.
I would try the Parasound JC-1+, they make stunning monos for a very reasonable price. It should be possible to fit them into this budget.
Reactions: GSOphile and Audire
Jpspock
118
56
93
57
If you like Pass, and as it seems you like Gryphon. Try to find Pass xa160.5 or 8.
Reactions: Audire
BlueFox
1,707
396
340
I love my Pass 600.5 amps. Whether playing classical in the 70db range or metal in the 80-90db range they sound great. Plus they never get out of Class A.
Reactions: Audire
Audire
1,055
1,180
275
FL Panhandle
Thanks. That’s good to hear. I play jazz, female vocals, and soft rock, so I think I won’t have any Class A problems. The 26so sound great, but the 600s I think will deliver the goods.
Audire
1,055
1,180
275
FL Panhandle
Kent English stated this a while ago to me:
My personal take on the X600.8's would be that they are very much X260.8 on steroids. What they bring to the table potentially is a greater sense of dynamic scale, which you would expect with all that additional wattage. The added Class A output capability, which is available from the X600.8 seems to bring out a little more weight and authority in the lower registers. If you have the space and budget, the X600.8 to my ears are a nice improvement over the X260.8.
analyzer
293
109
195
Torino - Italy
An out-of-choir voice: give a try to Coda Technologies. U.S. made. The last models have surprised me in overall sound quality and personally I preferred their model n.8 (V3 version, 400 Watts per Channel) versus Spectral 250/260, Vitus 100 and Pass x.250.8. Best than pass not by a large margin in any case significant to my ears especially in bass region and overall intelligibility.
N.8 it's not their flagship, Coda produces also two monos, n.61 are their best model but are obviously not cheap (almost 35 k for a pair).
If you consider a stereo amp their flagship stereo n.41 (also rated at 400 w/8 ohm) maybe a good choice (about 16 k).
Just my two cents
Marco
Reactions: Audire
Audire
1,055
1,180
275
FL Panhandle
Just my two cents
Marco
Thanks. Interesting! I’ll check these out.
TDX
223
167
115
I owned and loved my 260.8. But if you are seeking upgrade or try something else, you can have a look Pilium. They have stereo and monos. It will pair nicely with your M3.
Reactions: Audire
Audire
1,055
1,180
275
FL Panhandle
Many thanks. Yes that would be a consideration for our new room, but I didn’t think a set of Pilium monos is in the budget at this time. Pilium and Gryphon are on the list to eval for the new room, where there will likely even be some new speakers as well.
Daniel M
17
3
10
I’m surprised you think you need more power - if the 260.8s never leave Class A seems like you have plenty now.
