Mono Hum
Jul 26, 2010
232
Windsor, Ontario, Canada
#1
I bought a Ortofon Cadenza Mono cartridge used a few months back and used it off and on by swapping in and out of my SME 3012R tonearm. Initially everything was quiet and sounding good. Swapped out the cart for another then put the Ortofon back in yesterday and I now have a hum. I tried countless grounding methods, cables even headshell. Still hums. Any clues as to what is causing it. Hard to ask for help from dealers since I didn't buy from them.
awsmone
Active Member
Apr 7, 2014
1,061
2
38
Canberra Australia
#2
Commonest reason for hum is difference between the right and left ground
Check your interconnects are snuggly in and your pins
Try pulling out one set of pins and see if hum goes
If it was working without hum, it’s probably a loose connection
Also if using detachable headshell, clean the pins with a cotton bud maybe dipped in some white spirit
If that doesn’t work, come back to us....
To permanently get rid of any hum, run y connectors in heashell so only working off one ground set of pins
Jul 26, 2010
232
#3
When it was working quiet it was with a different phonostage. Anything else I use in the same arm is quiet in my current setup. I moved things around, tried cables, different grounding schemes etc...
I reached out to Ortofon and they answered with the typical script and then said if my phono was dual mono the hum will be present and to use a Y connector.
ddk
3,447
6
38
Utah
#4
Ortofon is correct, Hum from the left channel in a mono cartridge isn't unusual, you can mute or turn the volume down on that channel or unplug it from the phono. You have to look at the usual suspects if you're getting hum in both channels.
david
Dec 18, 2013
214
San Diego area
#5
The Cadenza Mono will hum depending on the phono stage in use. If it does you simply need to use the mono switch if the phono stage has one, or use a Y- cable to combine the two channels.
