MC cart reco needed for the Technics SL1200
AudioExplorations
653
5
I have just acquired a DartZ NHB 18NS preamp as I want to add an an analogue source to my setup and get back into vinyl.
I will use my technics SL1200mk2 turntable for the time being and later on move to something proper.
I am looking for a decent MC cart to use with this turntable/tonearm until I upgrade the table (and then also the cart).
Does anyone have any recommendations? I would like something under 200 USD$.
Ideally as neutral, resolving and extended as I can find in this price class.
Appreciate any suggestions!
4,700
Congratulations on the NHB18NS - an excellent preamplifier. Do you have the MC or MM phono module?
BTW, the more neutral cartridges I have owned were the van dan Hul's. I own a Sumiko Palo Santos and a vdH Black Beauty and find the vdH more neutral, but the PS more dramatic and dynamic.
AudioExplorations
653
5
Thanks guys. Micro, I understand the 18NS has both MM and MC capability built in, you need to re-solder a switch inside the preamp to enable one or the other. It is currently set to MC and therefore the interest in a MC cart. I will likely stick to MC in the future as I upgrade so I don't feel like messing around with a soldering iron to use a good cost effective MM cart like lets say the ortofon 2M red.
AudioExplorations
653
5
dcc - thanks for the suggestions, will these work with the s-shape arm (which i understand is a medium mass design)? Or is that not so critical, will most MC carts work with this table?
dcc
662
1,303
1,230
Continental Europe -
Long time ago, I had an Eroica on a SME 3009 and it worked great compared to the Shure V15VX it replaced. It should not be an issue. I guess it won't be that long until you will be wondering about moving to a stone body:)
TBone
1,237
1
Every MC type I've ever heard on that turntable/arm combo smeared & seemingly compressed the higher freq.
I'd consider a less extended type cartridge, like a Shure 97.
tb1
AudioExplorations
653
5
Very interesting... thanks for the advice. The shure M97xE seems to be an MM cart though. I think I will go for the Ortofon Vivo Red as this should work well for the time being and is not too expensive for now.
mep
17
Yep. I love it when you ask for explicit advise on something (in this case MC cartridges) and someone pipes in with exactly what you weren't looking for. Kind of like if I asked you what your favorite apple is and you replied with how much you like navel oranges.
TBone
1,237
1
The point I tried to make, which you obviously couldn't comprehend, is that no MC cart does the highs well on that machine, so perhaps a 97 would be the best choice. I think the original poster understood that, but you, well ... ?
tb1
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
tb1
Can you expand on that? A friend of mine just picked up an SL-1200MK2 and he asked me about an inexpensive cartridge, to which I suggested the 97.
mep
17
I got your point hambone, but you missed mine. He wanted to know what MC would go with his table and you offered up a MM cartridge. Again, apples and car tires.
TBone
1,237
1
It's beyond obvious what he was asking for, and it's beyond obvious that I knew exactly THAT, although I "contributed" with a different perspective. That's not in question, it's too obvious to be questioned, what is in question is why you contribute your silly comment (hambone?)
tb1
TBone
1,237
1
John, I've got a fair amount of experience with the 1200, stock units, KAB models, many different carts, and other modified versions. I can supply LP-CDR of various versions. Yet, the only MC versions that I've heard that seemed to open up the high frequencies instead of making 'em sound compressed, smeared and muffled, were versions which included a different arm.
In every case, I had issues with the higher freq. with ANY MC based cart on a Technics arm. Therefore. although I've not heard every MC alternative on a T1200 arm, I've heard enough to arrive at a general (but not absolute) conclusion that spending money on a MC cart might be a waste here, therefore I recommend using a cartridge like the 97 as a stop-gap, it rolls-off the highs, and personally, I prefer this type of response to a "bright/edgy" alternative.
However, it's not my choice, and in ONE silly way, I regret my contribution here.
tb1
4,700
AudioExplorations,
If by any reason you want to change the solder links remember to use a precision soldering iron with a very thin tip and some solder wick to remove any existing bridge. Do not heat the board directly - you will easily overheat it and damage the pads. I like a lot the Chemtronics Soder Wick.
mep
17
tb1
Are you really saying that the Technics arm that comes with the 1200 causes all cartridges to sound bright and edgy and you need to install a cartridge that rolls off the highs in order to enjoy the setup? And I don't know the answer to this question since I never owned a 1200 turntable. It was never on my radar.
AudioExplorations
653
5
mep - yes thats what he said, see post #7
micro - thanks for the advice, but i do not trust myself enough to take a soldering iron to the preamp, i will go straight to MC and live with smeared highs for the time being until i upgrade the TT.
TBone
1,237
1
Meepy, if you don't "know the answer to this question" and it's not on your "radar" ... then why you asking?
tb1
tb1
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I see we have 2 new members here ''''Hambone" and "Meepy". Welcome guys!:D
