KUZMA Stabi R , Silver or Wood?
groovemaster
110
234
283
As we all know, it all starts with a good recordplayer
Kuzma is one of those companies that gets me going. The Stabi player are available in wood or silver. I'm not quite sure yet what I want. The silver one goes well with the Audiospecials phono stage, but the wooden version R-W also has its charms. Sound-wise, the silver Stabi R-RW (Right Wing) has real punch in the bass without any softening, absolutely impressive. It doesn't have to hide even against more expensive competitors.
groovemaster
Addicted to hifi
4,610
2,039
265
52
Australia
groovemaster
I like the wood better. a beautiful looking turntable.
Reactions: gleeds and Audire
Audire
1,479
1,832
330
FL Panhandle
That Kuzma looks great - and of course they play even better. Two arms and a beautiful wood finish. Nice!
Reactions: Addicted to hifi
timztunz
157
104
150
Texas
Sorry to digress, but what is that AS Recompizer? I can’t seem to find anything on it.
Audire
1,479
1,832
330
FL Panhandle
Reactions: timztunz
groovemaster
110
234
283
The Recompizer is a function for extending the dynamics of long-running records. Unfortunately, everyone knows that records with very long running times have very tightly pressed grooves in order to fit on one side of the record at all.
The cutting enginneer has to lower the low frequency to limit the groove excursions. Result. Very thinned out, flat low bass. The Recompizer compensates for this reduction stepless in order to achieve the original dynamics again.
With modern, heavily compressed pop records of the seventies and eighties, this also works surprisingly well. The Recompizer is patented and only available with the German AS Phonolab 1.0. I wouldn't want to do without it.
The silver Kuzma player actually matches the reduced-to-the-max front design of the Phonolab even better the longer I look at it.
Greetings
groovemaster
Reactions: timztunz
Addicted to hifi
4,610
2,039
265
52
Australia
Greetings
groovemaster
Good looking as well but not as nice as the wood.
timztunz
157
104
150
Texas
Greetings
groovemaster
Thank you.
timztunz
157
104
150
Texas
fuzzypoodle
7
4
68
54
Hi I was wondering if there are any concerns around the motor and power supply integrated inside the Stabi R ? Thanks!
Ultrafast69
222
227
385
Seattle, WA
www.audio-ultra.com
Hello - Zero issue.
Reactions: fuzzypoodle
shakti
1,444
2,411
480
Cologne, Germany
no concerns so far.
fuzzypoodle
7
4
68
54
Greetings
groovemaster
H there, I have a Stabi R on order :) Exactly how you have it! Silver with the right arm wing. I also ordered mounting plate with an SME cut out for the right wing. If I want to mount another arm (I have Reed 3P 10.5 inch in mind), do i just get a blank plate and drill it ? Appreciate some guidance.
SOS
196
215
275
www.soundsofsilence.com
bazelio I agree, although the last 4 Stabi R tables we sold all had a Kuzma arm. I'm anxiously waiting for a customer to order the new SAFIR 9 arm for any of the Kuzma tables. :)
shakti
1,444
2,411
480
Cologne, Germany
why do you not ask your dealer/distributor to get from Kuzma a matching armboard?
SOS
196
215
275
shakti if you ordered your Stabi R thru a US dealer then they can request, per their importer (Elite A/V) the extra armboard for your Stabi R and Kuzma would predrill the hole based on your arm's specifications. There are several options for the extra armboard, it can be the full armboard like you are getting on the right or just a small "nub" of an armboard. Personally I love the look of the dual (L & R) armboards of the Stabi R, yes more expensive but looks wonderful.
(Kuzma dealer disclaimer)
Marcus
560
554
1,155
“Lively colored” Stabi R with SAFIR 9 from the recent (Multipak High End) audio show in Croatia…
