If he's got a complex system, and good, quiet components, he might be right that the plugs and sockets are causing more loss and noise than anything else in the signal chain. But he'd probably get the same effect from unplugging every cable, cleaning all the contact points and plugging them back in giving them a twist or two in the process, Did somebody say had had Conrad Johnson pre and amps? Tubes? Is he going to solder them into their sockets? How about the fuses?
Simpler system might be a simpler solution. I've got 4 cables in the entire system. I must be in signal heaven
Tim
Tim
