Herzan implementation question
Kingsrule
1,444
704
1,430
I have one TS140 to install in an all server system.
So where would I get the most benefit?:
1. Under the 4 bay QNAP
2. Under the Rossini, which is also used as preamp
3. Under the computer (has ssd) running roon
rockitman
7,097
414
1,210
Northern NY
make sure whatever gear you put on weighs enough to use the TS-140. I don't' think the standard TS 140 has a weight minimum...but you may want to check. I had my springs upgraded for greater weight capacity and for my unit and now there has to be at least 100lbs on it before it will work.
