Not particularly. The output impedance spec is 0.33-ohm into 8 ohms, a damping factor of about 24. JA measured a high of 0.465 ohms (at 20 kHz) for a damping factor of about 17 (was only ~18 at 20 Hz). You can see his measurements and expected response variation into their loudspeaker test load here: https://www.stereophile.com/content/dartzeel-nhb-108-model-two-power-amplifier-measurements
Thanks but this is for the 108 Model 1. Model 2 is significantly different and has more total power - not sure if the Class A has changed. Hervé has not answered…
