Contact Cleaning.... How often?
assessor43
312
194
128
I have just cleaned all of my connections from tube pins, interconnect, and ac power cords and cartridge leads. It does make a difference. How often do you do it?
RogerD
3,734
319
565
BiggestLittleCity
I use Deoxit about every 12 to 16 months on speaker connections.
Rocoa
118
88
135
Spain
Every 6 months at least.
Kontak at first and termination with Deoxit pro gold.
The SQ improves, no doubt.
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
Here is my method which is a pain but I do it only once:
1) Clean the contacts with isoprophanol
2) Polish, whenever possible, with a jewellery polishing paste (grren or white)
3) Clean again with iso to remove the paste leftovers, dry
4) Apply sparsely a dielectric grease (I use silicone-based Dow Corning compound for mil/airplane applications)
5) Connect firmly and try not to disconnect if possible; when disconnecting reapply a bit of the grease before re-connecting
Cheers,
Al M.
8,799
4,550
1,213
Greater Boston
Every 6 months.
First DeOxit D5, then DeOxit G5.
At least, that's what I'm striving for ;)
DaveC
3,899
2,142
495
Every 6 months.
I do this, but switched to G100 because G5 gets the stuff everywhere, but G100 is too much imo, so you need to apply it then remove as much as possible with a dry cloth or q-tip.
I think it's enough to apply G5 with a tiny brush, in which case one can is a lifetime supply...
I also use Furutech nano-fluid on terminations inside plugs and on any exposed wire to prevent corrosion, including on cables I build for ZenWave.
