Basement listening room. Best type of ceiling ?
GaryProtein
2,542
31
385
NY
Keep in mind that materials that keep sound INSIDE the room do not necessariiy affect the frequency response characteristics when listening to music.
Kcin
661
845
275
Canada
^^^Thanks for the good advice. There has been a change of plans....system going in the first floor great room. No renovation needed. :D
Good Move!
Pb Blimp
518
25
140
USA
agreed. i’m struggling with the same issue. low frequency issues are making my life difficult. i’m trying to make a 7.5 ceiling work. ultimately, going to have to move my new listening room.
Nyal At Acoustic Frontiers designed my basement room. In ceiling he did 12 inches of Roxul insulation, a layer of mass loaded vinyl then two layers of quietrock with green glue floating on these KNC hangers. Noise floor is very low (no external noise from outside room) and bass is tight. You might want to give him a call.
View attachment KNC Wave Hanger Layout.pdf
germanchu
7
Fantastic, mi learning a lot cause im going ti built somethin like this.
I hope moré photo, please!!
Loheswaran
436
101
273
In this order:
1. Rockwool between the joists
2. resilient bars to the joists
3. sound panel plasterboards
4. . glue acoustic membrane
5. Soundshield plasterboard 12.5mm
6. Plaster
7. Acoustic treatment as you see fit
That's what I am getting done at present in my loft - my suppliers tell me that this is what would be used in basements too.
steve59
356
112
150
my basement listening room is about 18x 26x 7'6" tall after furring the ceiling with 2"x2" to bury the conduit 5/8 sheetrock then 12"x12" acoustical tiles stapled to the ceiling. While the room isn't sound proof I can crank it up pretty good b4 family notices and the ceiling tiles really helped soften a previously harsh sounding room because of the low ceiling.
kach22i
Apr 21, 2010
1,591
210
1,635
Ann Arbor, Michigan
www.kachadoorian.com
The funny thing about acoustic tiles in my experience is that they still work when covered up with drywall.
What I mean is, after drilling a few holes in my basement ceiling I suspect an non-tee grid acoustic ceiling tile was secured directly to the underside of the ceiling joists (glued?).
Then years later in a remodel drywall was added over the top.
This is the only way I have come to explain what I consider pretty good room performance, better performance than I had in my old house consisting of wood lath and hand plaster walls/ceiling on the main level.
Sure too many other variables to list such as a concrete floor now verses sprung wood floor back then, but the current dampening properties over the old ringing properties cannot be denied.
DasguteOhr
2,415
2,587
645
Germany
my basement 7.5 feet high. soft gypsum plaster applied unevenly with a trowel, time-consuming work. reverberation time is good from 150hz to 20khz 0.45 absorbs well.
Gregadd
1,787
1,850
Metro DC
DasguteOhr
2,415
2,587
645
Germany
Yes. to keep reflections low. for exsampe in a recording room try the reverberation time between 0.2-0.3 from 20hz to 20khz you hear only direct sound from the speaker. For Music at home a lot of dry sounds liveless my opinion.
please i know this is not a correct measurement, a quick and dirty to see that it works. dayton mic measured in a Samsung tablet with the Audiotool app.
The microphon dosen't work under 150hz korrect. Screenshot_20210207-000846_AudioTool.jpg
