Hi folks -
I've repaired an Ayre VX-5 Twenty stereo power amplifier for a friend, but not knowing the original power up/down characteristics, I'm wondering if someone with a functional unit would be so kind as to describe their unit?
Here's what I note -
Upon power up:
Thanks in advance!
Regards,
V2
Upon power up:
- Rocker switch powered on
- Solid Red LED illuminates for 2 seconds, then goes off and the green ring on the push button illuminates
- If music is being streamed through the inputs during the power up process, you hear a brief bleed-through as it powers up, just prior to the active mute circuit takes effect
- Pushing the push-button toggles between blue LED (actively on), green LED (muted), or hold to revert to the green ring on the push button (standby)
- Place unit in standby with no LED, only the green ring on the push button
- Rocker switch powered off
- Green ring on the push button remains on for about 45 seconds as the unit discharges
- Green ring goes off and the solid Red LED illuminates until fully discharged
- If music is being streamed through the inputs during the discharge process, you hear a brief bleed-through of music as it discharges
Thanks in advance!
Regards,
V2
